Engine Rebuild Question
Discussion in 'XJ Technical Chat' started by Rsk_141, Sep 27, 2016.
  1. Rsk_141
    Rsk_141 Member
    Scotland
    I Am Having the Pleasure of rebuilding my Xj 650 RJ Seca 4ko engine. i'm in the UK so current engine number prefix is 4k0- i'm needing replacement crankcases (long story) have found engine cases prefix
    5V2- i believe these to be american import cases for a XJ650 RJ Seca, am i right in this belief?
    also will any pre YICS 650 barrels fit ie maxim yes i need barrels as well
    i know your all screaming buy a donor bike and swap the engine but there are not a lot of low mileage bike around, and i could be in the same predicament so i might as well bite the bullet and rebuild and have a bike that should last.
    Pre diversion 900 engines are an option but i think you need a lot of mods to fit or the cam cover cant be removed when in the frame, i may have picked it up wrong.
    please help!
    regards
    Gary.
  2. k-moe
    Cases from any XJ650 or XJ750 will work for you. The only thing of concern is to get Seca cases if you want to retain the solid-mount engine. I have Maxim cases on my Seca, and with some modifications to the mounts I now have a rubber-mounted engine.
    The barrels will swap between YICS and non-YICS engines; just be sure to block the YICS ports on your head if you have a YICS engine (tap the holes and use grub screws).
    This link will give you the information oh how to ID cases by the short-VIN
    TECH TOPIC: Model ID and VIN's
  3. Rsk_141
    Rsk_141 Member
    Scotland
    Hi thanks for the reply,
    I didn't know there were two types of engine mount. I will read through the ID and Vin
    Gary.
  4. Rsk_141
    Rsk_141 Member
    Scotland
    Result
    1982 XJ650 Seca USA : 5V2
  5. Rsk_141
    Rsk_141 Member
    Scotland
    Looks like a total rebuild
    Good Times !
    Stumplifter likes this.
  6. hogfiddles
    Don't forget the left shifter cover is different than the Maxim left shifter cover
  7. Rsk_141
    Rsk_141 Member
    Scotland
    I'm going to fit the US seca Cases as they're the cheapest I can find.
  8. Rsk_141
    Rsk_141 Member
    Scotland
    Got some goodies engine stand and some engine brackets
    Awaiting cases will keep you posted. (That's if anyone is interested)
    Gary .
  9. roymichaeldean
    roymichaeldean New Member
    London
    Hi
    I am splitting my crankcase on my 1997 XJ600 75,000 miles... as the bearing on the Output shaft in the transmission has collapsed....I just wondered how you lifted the engine, to fit it..?...to the Engine Stand.........
    I thought about the Engine Stand.....on more than one occasion, but...wasn't sure how to lift and drop 70kg without a Lift of some kind.....
    Good Luck...with your engine, rebuild...
    I'm still dismantling mine
    roy
  10. hogfiddles
    I just pick mine up.
