setting the cam chain timing...tips?
Discussion in 'XJ Technical Chat' started by kalyekid, Oct 3, 2016.
  1. kalyekid
    kalyekid New Member
    du quoin, il
    Thank you. I will certainly try this...
  2. Toomanybikes
    Tsawwassen bc
    Factory mass production is never perfect and the only way to get it perfect is a degree wheel and dial gauge on piston top. Usually one tooth either way will be farther away than acceptable.
