oil leaking
Discussion in 'XJ Technical Chat' started by sydmac, Oct 23, 2016.
  1. sydmac
    sydmac New Member
    ireland
    Hi all,had an engine oil leak, thought it was the head gasket, so I fitted a new base and head gasket
    But again I have an oil leak. But it's not from the head or base gasket,same leak as before,it seems to be coming out just below the head gasket front view,seems to be coming out where number two or three headstud stems are,just behind the oil cooler. Definitely isn't the head gasket and its too high to be the base gasket,anyone had this problem? Its a YICS XJ650 MODEL. Thanks.
  2. Jetfixer
    Ok here are the things I would ask was the surface clean and properly torqued? A good way to pin point a leak is baby powder put in area of leak .
  3. k-moe
    Is the oil cooler pissing oil out a fitting, or a small hole in the cooler?
  4. sydmac
    sydmac New Member
    ireland
    No oil cooler and fittings fine coming from the cylinder fins behind the cooler.
  5. k-moe
    Which is it?
  6. XJ550H
    the oil filter cover is not an oil cooler
  7. sydmac
    sydmac New Member
    ireland
    yes im well aware what an oil filter cover/housing and oil cooler look like and as i have said it's not coming from either of these. Thanks.
  8. k-moe
    It seemed like you were saying that you had no oil cooler.
    Next question. Who's head gasket kit did you use? There is at least one brand that supplies a cam tunnel gasket that is too thick.
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1 what they ^ said and...take a look see at the cam chain tensioner gasket.
    Gary H.
