Hello for Evesham, UK
Discussion in 'Hangout Lounge' started by yawning_cat, Oct 30, 2016.
  1. yawning_cat
    yawning_cat New Member
    Evesham,UK
    Hi all,
    Hoping this forum will help me out with woeful example of an xj650 ive just bought. It looked fantastic until I investigated and it seems the little fella needs some work!
    Riding it home, the back brake pretty much caught fire and the idle would rev to detonation proportions - so today i've got the carbs off for cleaning and weighing up that it needs a re-wire as its a fire waiting to happen! Also ordered up some brake shoes for the back.
    Any tips on the re-wire - ive looked at the ultima wiring kits - does it include the wiring to the regulator / rectifier etc?
    I also own a Buell xb9sx which is his stable mate ;-)
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard. 650Seca? It's been heavily moded. Imo you should start with sorting the things it'll need to some what correctly idle (the pods on cv carbs will prevent a good idle). Get the valves clearance in spec and do a compression test. Open the oil filler cap and see if the oil smells of fuel. If so, put the battery on a tender and don't start/run the bike until the issue has been sorted.
    Gary H.
    yawning_cat and Stumplifter like this.
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    welcome to the camp!
    Look at it this way - the Buell will get you from here to there until you lovingly resurrect your new XJ. Ask for help here, you will get it - there are a bunch of electrically minded folks here that should be able to help with your harness question(s).
  4. yawning_cat
    Evesham,UK
    Thanks for the responses already - it does run, starts up lovely and idles a dream until you ride and give it any throttle - after riding coming down the gears etc the idle races, ive read it could be air leaks etc ?
  5. hogfiddles
    Roc.... Remember, the other side of the ocean only got that style.....we call it the 650rj Seca, to differentiate from out 650 Maxim. They got the 'Seca' style as their standard xj650.
    Yawning cat--welcome! Take your time and read through the information overload hour, and the info on shim clearances, you're already on top of the brake issue.... Which is good.
    The high idle could be from a number of things, but most likely is a vacuum leak at the either the carb-to-manifold boots (gasket against the intake), or the throttle-shaft seals on the carbs. It's common especially at this age, and especially if the bike has been sitting a long time. These dry out and cause air leaks.
  6. rocs82650
    Middle Tennessee
    +1.Thanks for reminding me (11N vin). I did see that big UK in the title but thought I'd ask anyway.Wait...doggonit, I'm back confused...Canada didn't get the Maxim either did they?
    Gary H.
  7. hogfiddles
    Yes they did......
    1980-81 XJ650 Maxim Canada: 4H8
    1981 XJ650 Midnight Maxim Canada: 4W6
    1982-83 XJ650 Maxim Canada: 5N9
    The Seca----
    1982 XJ650 Seca Canada: 5V3
    1982-83 XJ650 Seca Turbo Canada: 16H
    Source: The Information Overload Hour
    Dave F
  8. rocs82650
    Middle Tennessee
    Thanks.
    Gary H.
  9. Toomanybikes
    Tsawwassen bc
    One note for Canada Seca's
    We also have the xj650rjc with prefix 15U
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Late chiming in, but I thought I'd mention that we got the Seca 900 too, perhaps more than youseguyz got, due to your protectionist tariffs on bikes over 700 cc. Also got 750x! Zoom!
  11. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    And oddly enough Canada also saw the XJ700 in 85/86.
    This bike looks to have an 18" front from an XS400 but with dual discs.
    Forks I'm guessing are XJ/FJ600.
  12. hogfiddles
    Yeah yeah yeah.... We know--- you're just trying to rub it in. That's ok, your odometers turn over a whole lot sooner than ours
    Nyah Nyah Nyah:p
    Hee hee
    Dave
  13. MattiThundrrr
    Nope! My score is just higher! Over 50,000 points!
  14. k-moe
    But your points are only worth half as much.
    hogfiddles likes this.
  15. MattiThundrrr
    Also, my "score" stopped going up a few years back!
