1982 Xj650 seca ticking sound
Discussion in 'XJ Technical Chat' started by Andrew Scoggins, Sep 30, 2016.
  1. Andrew Scoggins
    Andrew Scoggins New Member
    Sacramento, California
    hey guys, this is my first bike and I just rode it from California to Seattle and I don't really have any handy friends here in Seattle who can listen to my bike and tell me if it sounds wrong. Here's the video of my bike idling kinda warm kinda not, should I be concerned? Is it the cam chain or do I adjust the valves? It's just my only form of transportation and I'm nervous about it. Thanks for your time. (Oh puddle on the ground is water, tried to scrub off some gas stain).
  2. Jetfixer
    Sounds ok to me, have you adjusted valves yet? A clappy engine is a happy engine..when they stop making noise is a bad thing.
  3. XJ550H
    bike should sound like a sewing machine. when it makes no ticking you have a problem
    when you check the valves adjust the cam chain tensioner (unless you have an automatic one.)
  4. k-moe
    +3 All is well, though you should check valve clearances. Some of the 650 and 750 engines can also have noise from the exhaust cam tapping due to a bit too much endplay. It doesn't need to be corrected as it's not enough to cause damage; just a bit of noise.
  5. desmotom
    desmotom Active Member
    Canada MB
    Sounds good! Must be the pods!;)
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I don't think the pods can cause the engine to make the tapping sound in the video. They only cause whining noises from the owners.
    DrewUth, BigT, TheCrazyGnat and 4 others like this.
  7. Toomanybikes
    Tsawwassen bc
    Yea those pods let you hear intake valve noise that would normally get muffled by factory air box
  8. k-moe
    MattiThundrrr, BigT, desmotom and 4 others like this.
  9. mrdawson
    mrdawson Active Member
    Wisconsin
    it's the pods... engine is bout to explode. jk
    sounds fine
  10. hogfiddles
    Sounds pretty good :)
  11. DenCon509
    DenCon509 Member
    Central Washington, USA
    Sounds okay to me.
  12. Andrew Scoggins
    Hey guys sorry for the slow response but it turns out it was just the cam chain tensioner that I needed to adjust (was really loose). After I fixed that it sounded lovely, ran some techron through the bike and it got even quieter. Thank you all the ideas tho!
    Next is probably the exhaust manifold and speedometer. Wish me luck haha
    -Andrew
