Pulling Plug wire
Discussion in 'XJ Technical Chat' started by Jeremy Clark, Jan 21, 2017.
  1. Jeremy Clark
    Jeremy Clark New Member
    Mulvane Ks
    Am I wrong for thinking that if I pull one plug wire off the spark plug while the bike is running it shouldnt die? It shouldnt run great and may miss but not die. Right?
  2. wizard
    You would be right if all 4 are firing properly, where you going with this ?
  3. Jeremy Clark
    Mulvane Ks
    I got this bike for next to nothing and am trying to get it running better. I felt all the exhaust pipes and they all get warm when I start it up. It has a little backfire or pop under acceleration and a few after fires in deceleration. But like I said if I pull any one of the plug wires it sputters and dies. Im going to work on it later today but if I remember right if I pull #1 it immediately dies, no sputter just instantly dies. I have spark on all the 4 cylinders but to me it looks a little weak. I havent done a whole lot to it just changed the oil, cleaned the carbs, put it a new set of plugs and replaced the plug boots. The previous owner had an aftermarket exhaust with out a muffler, so I added a new cone muffler to it as well. This was someone else's "Project" that Im trying to get ready for the summer.
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Electrical troubleshooting is difficult (but only for me!).
    Throwing a dagger in the dark here, if the bike is tuned properly then pulling a plug wire should not stop it, because your bike is stalling it doesn't necessarily mean you have an electrical problem.
    Does the bike idle at a proper rpm?
    When is the last time the valve clearances were checked?
    Carb rebuild (wet set, colortune, synch)?
    I thought popping on deceleration is indicative of a lean running condition, no idea what popping on acceleration means.
  5. Jeremy Clark
    Mulvane Ks
    Yes the idle is smooth. Even the start up is easy. I was planning on syncing the carbs and running a compression test today. Your right Ill also check the valve clearance.
  6. XJ550H
    what bike are you running?
    have you changed the spark plugs or still using the ones that came with the bike?
    do you have a multi meter?
    you need to check out the charging voltage when the bike is started and running.
    then you should ohm out the ignition system
  7. k-moe
    Not necessaraly electrical. Carbs need attention.
    Popping and backfiring = fuel mixture issue.
    Starting and idling on all four is pretty easy to get right, and usually someone interested in flipping a bike will only go that far.
    Read first, then do. Contact Chacal for parts if you need any.
    IN THE CHURCH OF CLEAN
    The Information Overload Hour
    Oh, and do ALL of the things (at least all of the inspections). You will find that there are more problems than just what is obvious. The years take their toll.
    Stumplifter likes this.
  8. Jeremy Clark
    Mulvane Ks
    Sorry I should have started out by saying the bike is an 81 xj550. I did put in new plugs gapped at .25. I did find that it had 2 exhaust leaks so Im fixing that. Ive been chasing an intermittent short or something in the starter. I think I have it traced to the starter relay or some connection under the seat. If I wiggle the wires it makes a connection. I probably need to clean all of the electrical connections. So far having fun trying to figure it all out. But Im sure frustration will come.
  9. Timbox
    Timbox Well-Known Member
    As "K-moe" said above, "In the church of clean" and "The information overload hour" is a must read for the XJ's Lots of great information that will answer many of your questions.
  10. hogfiddles
    Ummmm... If the coil is good, and there's mice in the wire.....but there's a crack in the rubber, you might find YOU get a pretty good jolt----
  11. a100man
    a100man Well-Known Member
    Bedford, UK
    Hi all given that these bikes run just two coils and a wasted spark doesn't it need a 'full' connection to spark pairs 1-4, 2-3. Meaning that if you pull one plug lead two cylinders will lose spark which may be enough
    to stall the others..? Just thinking..
    J
  12. k-moe
    A path to ground is a path to ground. There will still be a spark at the connected plug. Running like that for an extended amount of time can damage the coil though.
  13. Jeremy Clark
    Mulvane Ks
    Just an update. Fixed the exhaust leaks. Took all of my electrical connectors apart and cleaned them. Checked the carb sync (it was good). Checked the valve clearances and they were all good. Stared it back up and sounds great. I pulled one plug at a time and it kept running. I have alittle more to clean up with the wiring. And hopfully by next week Ill be working on the forks and front brakes. Ill try and post a picture of my little build.
  14. Jeremy Clark
    Mulvane Ks
    went on my first test ride today. I lost one turn signal lense and on bolt fell out, other than that I was super happy.
    Timbox and k-moe like this.
  15. chacal
    Nice looking bike!
  16. Jeremy Clark
    Mulvane Ks
    Thanks so much
  17. Timbox
    Have to ask, how does that seat feel on your bike? I am doing a scrambler style bike & think that might be the kinda seat I am looking at. Nice lines and great color on your bike.
  18. Jeremy Clark
    Mulvane Ks
    I think it fits ok. The frame has a small "dip" under the seat. I kinda have a little OCD think and thought that it might bother me, but its not too bad
  19. Jeremy Clark
    Mulvane Ks
  20. C.john.B
    C.john.B New Member
    Calgary AB
    speaking of seats... Does anyone have advice on where to purchase a prefab seat? was going to build my own but would rather buy a plug and play at this point
  21. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Nothing is going to be plug and play. You can find universal cafe seats and such online but you will still have to fabricate mounts
