1980 xj650 ignition coils?
Discussion in 'XJ Technical Chat' started by Dylanfaircloth, Apr 26, 2016.
  1. Dylanfaircloth
    Dylanfaircloth New Member
    Las vegas
    My ignition coils have got out a while ago, now finding time to start working on the bike again.
    Ive been searching for ignition coils but not having to good of luck on finding brand new ones. Does anyone have any suggestions on which coils i should run? and also ones that won't burn a hole in my wallet. This will be my first time installing coils when i get these so if anyone has any helpful advice that would be great!
    Thanks!
  2. Toomanybikes
    Tsawwassen bc
    Check out Dyna could have used them and are great on any bike
  3. k-moe
    Start a conversation with Chacal.
  4. Jetfixer
    Try finding a set of CB750 Honda Coils , they mount to stock location you just have to flip them over. They are Hitachi coils ( same manufacture used by Yamaha) and have removable plug wires. I paid 25.00$ for the pair my bike runs great with them
    wink1018 and DrewUth like this.
  5. DrewUth
    DrewUth Active Member
    South Jersey
    ^^^ That!
  6. Dylanfaircloth
    Las vegas
    Sweet thanks man, would the plug wires from my coils now work with those or would I need anew set of those? Sorry it's my first time doing this so not sure if coils will come with those or not ?
  7. Dylanfaircloth
    Las vegas
    Do you have a link to his account or something? I'm still kinda new to these forums
  8. Jetfixer
    Look at the top left corner click on the xj4ever it will take you to the catalog it quite extensive . Start an IM message or email he replys fast and shipping is quick.
    Dylanfaircloth likes this.
  9. Jetfixer
    sorry right corner of page
  10. k-moe
  11. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    And the Honda coils fit under the tank with no issues?
    The Honda could are a lesser expensive upgrade to the factory Yamaha coils, in that the wires can be replaced without purchasing new coils or major surgery.
    And, if my research is correct, they are 2.5 ohms, just like ours .
  12. k-moe
    Correct on all counts. Jetfixer was the one who first used the CB750 coils.
  13. XJ550H
  14. wink1018
    Muncy, Pennsylvania
    Already sourced out a pair of coils. Actually, a complete kit. One that includes two coils, 6 feet of wire, two NGK straight boots and two 120° boots. All for $68.
    Thanks all...
    MattiThundrrr likes this.
  15. Polock
    We need a product review on those, a lot of guys need coils
  16. wink1018
    Muncy, Pennsylvania
    I'm your huckleberry.....
    I will add my opinion after they arrive and installed on my 81 650 Maxim.
    Stumplifter likes this.
  17. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Add '80 650 Maxim to your signature please.
    Gary H.
  18. wink1018
    Muncy, Pennsylvania
    Installed the CB coils today. Easy install. As soon as Photobucket starts working, I will submit pics.
    Initial thoughts: no perceived performance gains. Decent spark. Definitely a lesser expensive replacement to stock XJ coils.
  19. k-moe
    As expected. Spark alone won't change how an engine performs, unless the spark is insufficient to begin with.
    Marketing...
  20. wink1018
    Muncy, Pennsylvania
    Here are the install pics...
    IMG_20170206_143247530.jpg IMG_20170206_143237964.jpg IMG_20170206_143217223.jpg IMG_20170206_143159932.jpg
  21. XJ550H
    you may want to flip those quick disconnects on the left side coil . the wire looks like it will get pinched under the tank mount
  22. wink1018
    Muncy, Pennsylvania
    Not at all. They are behind the rubber. (Inboard of the tank mount)
  23. XJ550H
    pinched chaffed behind the rubber to the frame. time will tell
  24. wink1018
    Muncy, Pennsylvania
    I have never seen the mounting system of a 550's tank. However, there is about half an inch clearance between the rubber mount and the frame where the wires of the coils have been relocated to by this modification. And on my 650, the "U" shaped receiver of the tank does not protrude inboard past the lip of the rubber isolators.
    However, like you stated, time will tell.
  25. Polock
    nice, thanks
  26. k-moe
    That's how my auxiliary light wiring is routed. There's plenty of room, and no chafing.
  27. Jetfixer
    I have no interference with wire rubbing on tank.
  28. robbo
    robbo Member
    uk
    i am fitting new coils that need spade terminals fitting to the wires.does it matter which wire goes to which connector as they are not marked + or -
  29. XJ550H
    no it does not matter
  30. robbo
    robbo Member
    uk
    thanks for that.sorry to jump on this thread but i am not able to post a new thread.or might be just a senior moment.
  31. Caleb Howard
    Caleb Howard New Member
    Chattanooga TN
    Does anyone know if the cb plug wires screw in to the plugs? Or how they hook up?
  32. Jetfixer
    I run 82 Honda CB750 coils on my XJ750 Seca these are a direct swap in mounts just like stock coils and have replaceable plug wires. Cycle Recycle Part 2 has them new for like 39$ each and they also sell the plug wires and caps as well. These coils work great and been using them for 3 yeas with no problems.
  33. Caleb Howard
    Chattanooga TN
    Thank you so much I just ordered me some
  34. Caleb Howard
    Chattanooga TN
    H
    Hey I hooked mine up but I'm not getting any fire did you use the same wire hookups as the originals? And when getting more plug wires do I order them for the 82 coils?
  35. Jetfixer
    Yes used original wires on harness .
  36. Penz529
    Penz529 New Member
    Honolulu
    Hi!
    Was wondering which brand of cb750 coils you got? Are the ebay specials any good? What are the ohm readings on yours?
