1983 XJ750 Maxim
Discussion in 'XJ Modifications' started by DeanXJ750, Feb 28, 2016.
  1. DeanXJ750
    DeanXJ750 Member
    Ontario
    Ok just went to check and my new bulbs are 10watts.
    That puts them at a 0.83amps
    2.2-0.83 = 1.37 Amps difference
    1.37/12 = 0.11 Ohms
    0.11x2 = 0.22 Ohms
    Sooo....!
    I need to buy two ceramic resistors rated at 0.22 Ohms?
    I see after shopping for resistors that they come rated as;
    5w 0.22Ohms
    10w 0.22Ohms
    50w 0.22ohms.
    100w 0.22ohms.
    I would purchase the 10w one correct?
  2. k-moe
    The 10 watt resistors will do fine, especially if they are enclosed in heat sinks.
    DeanXJ750 likes this.
  3. chacal
    Or, you can buy a signal flasher unit that is solid-state, rather than mechanical (solid state flasher will flasher any bulbs, regardless of wattage). You'll lose the self-cancelling feature of the signal system, but many people are not bothered by that.
    DeanXJ750 and XJ550H like this.
  4. XJ550H
    chacal said it better and first
  5. k-moe
  6. DeanXJ750
    DeanXJ750 Member
    Ontario
    So If I walk into the store and ask for a solid state flasher relay I'll be ok? Is there any specific type I should get? Pins?
    Going to try to get one today and put the turn signals behind me.
    Any advice on which one to get would be greatly appreciated.
  7. mrdawson
    mrdawson Active Member
    Wisconsin
  8. DeanXJ750
    DeanXJ750 Member
    Ontario
  9. DeanXJ750
    DeanXJ750 Member
    Ontario
    Just moved to a new house with a new garage!
    Work on the bike has continued in full swing.
    I will post some more photos ASAP
  10. mrdawson
    Wisconsin
    welcome. Glad it worked for you as well
  11. DeanXJ750
    DeanXJ750 Member
    Ontario
    Hello everybody! 20170211_194833_000.jpg 20170211_194256-1.jpg 20170211_194232-1.jpg 20170211_195301.jpg 20170211_195314.jpg Back at it!. Been a while....
    but work has started back up on the Maxim!
  12. hogfiddles
    Ow, my EYES...... I'm BBLIND!!!!!!
  13. DeanXJ750
    DeanXJ750 Member
    Ontario
    Seems like I have a parasitic draw that's killing the battery:(
    Everytime I shut it off for an extended period of time and come back to the bike, its dead.
    Anyone have any recommendations for an ON/OFF kill switch directly at the battery to maintain its charge?
    My thought was to shut it off at the battery and eliminate the parasitic draw from the battery as opposed to finding the source of the draw.
    Sounds lazy, but seems like the easiest route..?
    Anyone else gone through this with their XJ/Battery?
  14. k-moe
    How long is an extended period of time? Leave any battery sit long enough and it will discharge, even if disconnected.
    You need an automatic battery maintainer.
  15. XJ550H
    charge the battery and pull the main fuse. battery connects to main fuse before anything else. see if you still have a problem.
    how old is your battery?
  16. DeanXJ750
    DeanXJ750 Member
    Ontario
    Going to get a tender today!
  17. DeanXJ750
    DeanXJ750 Member
    Ontario
    Battery is just over a year old.
  18. AndrewDavis
    AndrewDavis New Member
    New Jersey
    Looks great! I have the same bike. I'm looking to do the same thing replace the ugly stock shocks for something similar.
    What size are they? I apologize, I'm new to this, is there also a weight/load requirement I need to be looking out for when purchasing new shocks?
  19. DeanXJ750
    DeanXJ750 Member
    Ontario
    Hello fellow XJ Bikers!
    Work has begun again on the XJ750
    White walls mounted!
    Painted final drive/drum and forks.
    Now it is time to paint the tank... again..
