Entire '82 XJ650RJ SECA ASK FOR PARTS
Discussion in 'For Sale, Trade/Swap, Wanted' started by Jon D, Feb 15, 2017.
  1. Jon D
    Jon D New Member
    Massachusetts
    I bought the bike for $100 and thought about fixing it up, but it was a little too much for me to handle. I'm in Massachusetts if someone wants to pick up the bike as a whole or you can ask for parts. I have the entire bike with part is various conditions, bike is non-running and motor is seized for unknown reason. A lot of parts are solid and some are rough. Post what part you'd like me to pull and PM me an offer and well work something out.
    I can supply pictures or video on demand.
  2. ralden96
    ralden96 Member
    new york
    hi - what is the condition of the handlebars? i might be interested in them. pictures would be helpful. trying to resurrect one myself. thanks.
  3. Jon D
    Jon D New Member
    Massachusetts
    Largely okay but some large rust patches at the risers, unsure how deep but may need replating or a sand and paint job. Will see what I can do for pictures soon.
  4. Taylo105
    Taylo105 Active Member
    San Diego CA
    Interested in the carbs, and the rubber intake manifold between carb and engine. Any available high-res pics would be appreciated. :D
  5. hogfiddles
    Pm'd on side covers, seat, and tank
  6. Jon D
    Jon D New Member
    Massachusetts
    Also if it wasn't clear enough as a small disclaimer, the bike and its parts are obviously as is. I can describe things and take pictures but I cannot guarantee functionality or conditions. Ask about any concerns in advance or pictures if needed and understand what you're buying. Thanks to everyone for their interests so far!
    http://imgur.com/a/WeTot here's some pictures for now will be taking more later.
  7. nixadmin1
    nixadmin1 New Member
    Hawaii
    Jon
    PM'd about instrument cluster & and turn signal
  8. Jon D
    Jon D New Member
    Massachusetts
  9. NSchultz
    NSchultz Member
    Phoenix, AZ
    pm'd on front calipers and brake discs.
  10. hogfiddles
    Interested in the seat......
  11. Bmgalena
    Bmgalena Member
    Joplin
    I am in need of a starter
  12. hogfiddles
    Any Xj-series 650,700,750 X, or 900 starter will interchange
  13. trent
    trent New Member
    guelph
    headlight here
  14. Anant Kamasaku
    Anant Kamasaku New Member
    can you send me pictures of the front break master cylinder? I want to make sure its compatible with XJ750
  15. hogfiddles
    OP Hasn't been seen since March 19, 2017
  16. jofish3
    jofish3 New Member
    ga
    Can you send me some pics of the carbs if you still have them please and thank you
  17. Jon D
    Jon D New Member
    Massachusetts
    Too all who contacted me, I'm sorry I went inactive and left a lot of you hanging life got in the way in the form of too many work hours and a large set of winter storms and some damages to my garage. I still have the bike in full and am going to be stripping it over time and stripping it at the requests of buyers. Feel free to message me again and I'll be checking inbox daily and will try and get a within a week turn around on any parts requested.
    I DO have the stock airbox in largely perfect condition, it has one crack in it that can be sealed relatively easy with some glue. I also have a DENT free tank with working petcock, the paint will need to be stripped or I'll end up stripping it myself and selling it for a bit more. No keys but has cap.
    I have the complete rack of carbs but they have been semi disassembled and I'll deem them as virtually unusable except as parts. Diaphragms/floats are all there and hole free but 20 years of black gooey gas and rust has eaten at the throttle slide and the rod that moves it. Choke pin is broken. I have the floatbowls though, and managed to clean the idle jets of 3 of them.
    Again apologies to anyone who got ignored, or dropped. I'm free and clear to help and ship now. Ask away
  18. sybe
    sybe Active Member
    NYC - Brooklyn
    I sent you a PM, i am interested in the gas tank.
  19. Jon D
    Jon D New Member
    Massachusetts
    Pulled the light bucket, both calipers, all of the fairings, panels/seat, and the starter motor off the bike today. started going through the lights and signals, all seem to work fine but the left rear.
  20. carlton
    carlton New Member
    calif
    Hello do you still have have exhaust headers ? and are they in good shapePics?
  21. Jon D
    Jon D New Member
    Massachusetts
    Rusty on the backside though look solid, would definitely need to be sanded and painted or re-chromed.
    Also just drilled the cap off the tank to check rust, it's not that bad age considering, patches of rust here and there and some pretty minor pitting. I'm throwing some evaporust on the inside for a while to see if I can't lift most of it up. If it doesn't sell fast enough I might just have it blasted/painted by my friend at poly dip and use it for a future project.
  22. Jon D
    Jon D New Member
    Massachusetts
    Small update, the rust on the inside was MUCH more minor than I thought, been swishing a gallon of the evaporust around inside and it's coming straight off and leaving nothing but clean bare steel. Going to have it blasted externally and bondo any minor pitting there might be and have him put this military primer on the tank that he uses for his job. Will either sell it as a prepped tank or maybe throw it on another bike.
  23. hogfiddles
    Jon, I'm interested in the carbs and carb parts.....please send me a conversation--
    Dave fox
  24. Jon D
    Jon D New Member
    Massachusetts
    in-depth message sent, friend!
  25. 13wheel
    13wheel New Member
    Western NY
    I am interested in the speedometer and fuse block if available
  26. Jon D
    Jon D New Member
    Massachusetts
    PM me, both available
  27. Jon D
    Jon D New Member
    Massachusetts
    Update: Carbs have been sold and shipped to a forumite.
  28. hogfiddles
    Jon, your inbox is full
  29. Jon D
    Jon D New Member
    Massachusetts
    Freed it up sorry bout that
