What's the best way to clean up my chrome pipes? Seca 750
Discussion in 'XJ Technical Chat' started by stv1991, Feb 21, 2017.
  1. stv1991
    stv1991 Member
    Pipes are in good shape overall, very, very minor rust spots. Just wondering the best method to clean them up without damaging them.
    coke and aluminum foil the rust spots will turn black from the phosphoric acid
    Jetfixer likes this.
  3. k-moe
    Or just water and aluminum foil if you don't want black spots. The rust spots are from pinholes in the chrome, so the rust will return. Just repeat the process when it does.
    Stumplifter likes this.
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    ^^^^ that works.
  5. hogfiddles
    I use #0000 steel wool (bronze wool when I can find it) and a good cleaner/rust remover/polish like Suzuki SP5B, Honda SHINE, Yamaha cleaner/polish, S100, etc..... I even used kroil, and pbBlaster----
    Light elbow grease, so you don't scratch, til clean then keep polished and waxed
  6. stv1991
    stv1991 Member
    I never knew about the aluminum foil trick. Looks interesting. Brass wool or aluminum foil won't scratch the pipes?
  7. BigVinceDawg
    BigVinceDawg Member
    South Dakota
    aluminum foil wont scratch the chrome, I would assume that brass wool or steel wool, or wire brushes would scratch it up.
  8. k-moe
    Chromium plating is very hard (physical hardness). Aluminum and brass are soft metals. Extra-fine steel wool is a tool used for polishing other metals, including chromuim plating.
  9. hogfiddles
    Well.... With 7 trophies on the shelf, I think things clean pretty well with the #0000 steel wool----
    k-moe, Stumplifter and TheCrazyGnat like this.
  10. Toomanybikes
    Tsawwassen bc
    And this stuff works fairly well and leaves a protective coating
  11. stv1991
    stv1991 Member
    Thanks guys. Good information to work with. I'll get her cleaned up and post some pics this spring.
