Racing Idle once warm.
Discussion in 'XJ Technical Chat' started by Ass.Fault, Oct 10, 2007.
  1. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    My Seca starts fine, and idle perfectly.
    Until it is at a warmer temp and I pull clutch and she hits 2.5-3k rpms
    I release the clutch to put small load on her and back to 1.1k
    ...I mean I can hold her back w/ my legs "small load", nothing intense.
    I have all my money on a carbs issue, but what comes to mind.
    Got the bike about 4 months ago from PO. He kept it in decent condish.
    She does not have problems at any other time. Screams like you know what...
    ...I think I change my vote to Vaccum(sp)...
    Any one care to ventue a guess, and possible fix while ya at it:)
  2. Gene
    Gene Member
    Madrid, Spain
    I have the same problem. Turn idle screw down and is fine warm, but doesn't idle when cold...
    Still haven't figured it out, but I have no colortune o YICS nor money to get them.
    Do all the cylinders fire when cold? (All exhaust pipes hot)
  3. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Question: does it idle high when in neutral, too? Or, if in neutral, when you squeeze the clutch lever the idle rises and then drops when you let it back out?
  4. Gene
    Gene Member
    Madrid, Spain
    In my case, in neutral the idle races too, doesnt matter where the clutch is. I have to put first and let clutch go to bring it down.
  5. Ass.Fault
    I will give that a shot soon, but may not have a chance for a bit.
    May be this weekend though
    What are you thinking doc, is it broke? :lol:
    In the meantime what are some of the possible senarios?
    There will be sometime before I have a chance to check, and want to have all ducks(quack) in a row before jumping in the pond.
    Thanks for the replies.
  6. PghXJ
    PghXJ Member
    Pittsburgh PA
    The idle should be adjusted when the bike is fully warmed up. If it then doesn't idle when cold, your enrichment circuit may not be working properly, or you sync may be off.
  7. schmuckaholic
    California
    As I mentioned in another thread, I had a racing idle problem when warm. Seeing some dribbling fuel from my petcock, I replaced the spring on the vacuum diaphragm with what turned out to be a stronger one. Didn't fix the fuel leak, but it did cure the racing idle.
  8. Ass.Fault
    well i would have never thought petcock...
    it does not leak though, at least not as of two weeks ago
    thats when an inline filter was on.
    It raced before that too BTW
  9. Danilo
    Danilo Member
    Vancouver canada
    Now THAT Petcock Vac leak) is interesting .
    Many if not Most of these bikes have (sooner or later) the Racing Idle problem. Often it persists even after serious carb work.
    Your answer/discovery is likely a V good one Thanx
  10. Ass.Fault
    just a sync issue and idle setting after all.
    thanx PghXJ
  11. PghXJ
    PghXJ Member
    Pittsburgh PA
    glad you got it straightened out.
  12. IkeO
    IkeO Member
    Milwaukee, WI
    wait. how did you straighten it out. i have this same problem idle cold at 1k but idle hot randomly at like 2.5k.
    how did you end up fixing it?
  13. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    Set your idle when the bike is at normal operating temperature then sync the carbs.
