carb pilot jet stripped
Discussion in 'XJ Technical Chat' started by nillawaferjam, Mar 10, 2017.
  1. nillawaferjam
    nillawaferjam Member
    Elkhart in
    Just bought a new carb for my 1981 xj650, came with out pilot jets. So I used the pilot jets from my old car which wasn't worth rebuilding. In removing one of the jets from the new carb I marred the threads in the housing and cannot get the jet to screw back in. I can't use any of the housings from my old carb because it's a 550 and I have a 650. Does anyone know the thread size of the pilot jet? Also I'm gonna need a new jet.. Thanks!!
  2. k-moe
    I'm somewhat sure that the Mikiuni carbs from the 550 have a different thread pitch than the Hitachi carbs on the 650, which is why they won't thread in to the 650 carbs.
    Start a conversation with Chacal. He can hook you up with jets, and the thread pitch and size so you can get a tap to fix the marred threads (he might even have a tap to sell).
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Pilot jet from your car!? Probably not the right size and the threads may not be metric. Contact Chacal for the correct jet and he probably can give you the correct thread.
  4. k-moe
    I read it to mean old carb.
  5. tabaka45
    Brunswick, Georgia
    That makes more sense. Brain dead on this end I guess!
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    That's two of us... exclamation points and fireworks going off in my head cuz I thought it was from the car!
  7. XJ550H
    did no t know hatachi used that style pilot jet Could be he is talking pilot air jet from mikuni
    mikuni pilot jet 550
    hatachi pilot jet
  8. nillawaferjam
    Elkhart in
    Well this is about the most active forum I've ever used, really impressed. The jets I used from the 550 all threaded in fine except for the one which came with my carb. It actually stripped on the way out. Those jets aren't looking firimiliar, I'm talking about these:
    It is a Hitachi carb
  9. MattiThundrrr
    Hey, thanx for the great pics. I just learned something from #3. I never saw the Hitachi logo on the bowl before. Jeez, I gotta take my carbs to church!
  10. k-moe
    Those aren't jets. They are the idle mixture screw needles. They came in two thread pitches, depending on what year the carbs were manufactured in.
    I still suggest starting a conversation with Chacal. Unfortuantely I am traveling and can't access my toolbox to tell you the tap sizes.
  11. nillawaferjam
    Elkhart in
    Thanks everyone. Got in touch with Chacal, he hooked me up with what I needed
  12. hogfiddles
    Idle mixture screw---- not a jet
  13. hogfiddles
    Oops didn't see kmoe already got to ya. Yes, two different threads-- coarse and fine.
    -also just saw you're hooked up with Chacal. You'll be ok now
