Wanted Right side (battery) cover for 750 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by Wintersdark, Mar 11, 2017.
  1. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    Just looking for a battery side cover for my 82 750 Maxim. Not too concerned about condition.
    Sadly, ebay is chock full of left side panels, and the only right side panel I've found online was absurdly priced. Anyone have a spare kicking around anywhere?
  2. hogfiddles
    I guess it depends on what you consider "absurd". If you think $35.00 is absurd, your right------that's absurdly LOW. If your think $135.00 is absurd, you're wrong----that's in te ballpark.
    What price range are you trying to stay in?
  3. Beech
    Beech New Member
    Michigan
    I have a right side cover that I had off and was going to paint/ and or modify from an 83 Maxim, that I am pretty sure is exactly the same for an 82.
  4. hogfiddles
    81-83 xj750 Maxim are all the same, except for color combinations
  5. Wintersdark
    Fair enough. I was expecting around the prices people are asking for the left side panels (which are generally $50-60cdn on ebay). I can appreciate that the right side panel is clearly harder to find, and people want more for it as a result.
    If I can't find one at a lower cost, that's fine, and I'll have to figure out something else (hence the thread in the Modifications section asking for ideas :) ). I'm not really set on a bone-stock look, so if I have to go that route, that's perfectly ok.
  6. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    Do you still have it?
  7. Beech
    Beech New Member
    Michigan
    Sorry, but they are gone.
  8. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I have always been curious why there are so many left side covers, but so few right side covers for sale on ebay. My right side cover is a more faded because of the side stand lean. Perhaps the plastic was damaged by sun UV on more right side than left sides?
  9. Bmgalena
    Bmgalena Member
    Joplin
    I always thought it was because it was removed more often to get to the battery so the tabs got broken more
    Dadoseven likes this.
  10. Dadoseven
    Dadoseven Active Member
    Omaha
    I suspect it is this ^^
    Removed to access the battery; then misplaced, stepped on, broken, etc.
  11. cgutz
    SE South Dakota
    Duh, thought of that sometime after I posted above...guess I was fixated on the fact that the paint on mine is faded more than the other side, so was thinking about UV.
  12. XJ550H
    Have you ever seen a jack or spare/flat tire on the side of the road?
    with the right side being taken off to check battery, charge battery, check solenoid the cover ends up on the ground left behind , stepped on or just broken from constant removal.
    Wintersdark and Bmgalena like this.
  13. amfmtxca
    amfmtxca Member
    Cool thanks for getting back to me
  14. hogfiddles
    The side covers for 750 maxim have a metal frame.
    This!
    And this!
  15. Toomanybikes
    Tsawwassen bc
    You still looking for a cover? Just got a bike that I will be parting out
  16. Walt
    Walt New Member
    Phoenix, AZ
    Yes. Need right side cover if it is Maroon 1983 in fair condition. Please post pic.
  17. Toomanybikes
    Tsawwassen bc
    Those covers have been sold, sorry
  18. XJ550H
    right side cover I would not be pickey about the color just paint it
  19. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    What xj550h is saying is that the right side covers are becoming a bit rare. Holding out for the perfect match might take a while.
