Video Link to my Seca Rebuild
Discussion in 'Hangout Lounge' started by Nick, Apr 21, 2006.
  1. Nick
    Nick Member
    Vernon, BC Canada
    Thought I would post a link to a video I shot just after reassembly of my carbs. I replaced the butterfly shaft seals and the fuel passage o-rings.
    http://www.fileden.com/public.php?actio ... ad_id=1702
    I bought this bike in boxes and is still a work in progress. This past month is the first time this engine has run in who knows how long. Working on the fuse block at the moment, brakes, forks, paint, and ?? next! :) Hopefully not too much longer and I will be riding! :D
  2. CTSommers
    CTSommers Member
    Philadelphia, PA
    Nick you champ the bike is sounding excellent. Great work putting back the soul into that bike. I truly believe that the world is a slightly better place with one more bike on the road.
  3. Jazzmoose
    Jazzmoose Member
    Pineville, LA
    Whoa...that's sweet, Nick!!
  4. xj650maxim82
    xj650maxim82 Member
    Georgia
    I got a quick stupid question. Was there anything special you had to do with your makeshift gas tank. My tank has rust on the inside and I wont get my restore kit for another week but I would at least like to see if I can get the bike running but i was afraid I would flood it if i just hooked up somethine plastic.
  5. Robert
    I use a plastic gas can with a nipple from a gear oil container. I had to cut the threads off the oil cap but I made it really quick and smooth. Works so long as you have one of the older types of gas cans with a vent (can't get those in California anymore, darn C.A.R.B.). I just tilt the sucker over and I've got two gallons of fuel. Bungee the container on the bike and your golden.
  6. Nick
    Nick Member
    Vernon, BC Canada
    Thanks for the comments guys, I'm very pleased with the way she runs, just gotta get her on the road now!
    The fuel tank is from a old weed wacker. I plugged the original fuel line hole, it was only about a 1/8" line, and too close to the cap for a gravity feed. I drilled and tapped a hole in the other end for the brass adapter and copper line that the bikes fuel line can press over. I need to leave the cap loose for venting.
    xj650maxim82, your bike shouldn't flood, if it does you have a float valve problem in the carbs and that should be fixed!
  7. zapperredtank
    zapperredtank Member
    lincoln uk
    great video nick you can show so much more with video than you can in spoken word keep us informed on you work
    best wishes from the UK
  8. Oblivion
    Oblivion Active Member
    Northeast Illinois
    Very cool. Lookin'/sounding good!
  9. Speedwagon
    Speedwagon Member
    Littleton, CO
    Is that the stock exhaust? My holy stock exhaust doesn't quite sound like that. You have a bit more rumble in yours.
  10. Nick
    Nick Member
    Vernon, BC Canada
    stock exhaust, located from many hours on Ebay, one muffler from eastern U.S., rest from western Canada!
    I''m very pleased with the overall appearance and sound from used parts!
  11. Oblivion
    Northeast Illinois
    It sounds about like mine (w/ stock pipes). The Secas really have a pretty distinctive throaty rumble. My old neighbor (the P.O.) always said he could hear me coming from two blocks away. Not like my buddy's VMAX, which I could hear, or more accutrately feel, 6 blocks away, but still - distinctive.
