Maybe a stupid question..again! Swingarm/driveshaft
Discussion in 'XJ Technical Chat' started by Alacroix, Apr 14, 2017.
  1. Alacroix
    Alacroix New Member
    81 Yamaha Seca 750. Finally putting this thing back together slowly. Kind of forgot what I did when I disassembled it (5 years ago). I have the engine in. The driveshaft whole. Meaning U joints at one end and splined shaft at the other (with washer and seal). I need to get this through the swingarm. What do I need to do?! What do I need to undo?! Snap ring at driveshaft end? Help! Thank you in advance!
  2. k-moe
    The u-joint slides off of the driveshaft. Some have a snap ring inside, others don't; so you nay have to give a good yank to get the u-joint to separate from the shaft.
    There are no stupid questions.
  3. Alacroix
    Alacroix New Member
    So what I meant to ask was the snap ring outside of the U joint not the "driveshaft" end. But I understand. I think. I can't find my set of snap ring pliers so I'm left with one pair which is too big. I should be able to get it done after work. Thanks!
  4. k-moe
    There is no snap ring outside of the u-joint that has to be removed. If you are looking at the drawing on the parts fiche, the snap ring shown is the one that holds the oil seal onto the final-drive end of the shaft. That does not have to be removed.
  5. Alacroix
    Alacroix New Member
    Not my picture but there is a snap ring on this end also. So this spline should just pull right out correct?
  6. Alacroix
    Alacroix New Member
    I'm still working so haven't tried anything yet.
  7. k-moe
    Yes the splines just pull out from the u-joint. As I said, none of the snap rings need to be removed.
  8. Alacroix
    Alacroix New Member
    Ok perfect. Thanks!
  9. Alacroix
    Alacroix New Member
    Finally got time to mess with it a little. Put it in the vice. Used a screwdriver and pressed it out. Simple! Thanks for your help!
