83 Maxim tank. clut, slipt beat and battered.
Discussion in 'XJ Modifications' started by XVFinishes, Oct 19, 2007.
  1. XVFinishes
    XVFinishes Member
    Toledo, Ohio
  2. SaltyCITYXJ550
    SaltyCITYXJ550 Member
    Salt Lake City, UT
    Having welded quike a few things in my life, I may need to keep my comments to myself. I must admit I like the shape!
  3. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    Its self explanatory "flux core mig"
  4. Robert
    Geez... you guys are making me really not like my recent purchase of a flux-core MIG welder for my toys. I still need to take a welding class (the welder fell into my lap at $50) but at least I have the best money can buy (from Harbor Freight that is).
  5. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    flux core works fine, just touchy on thin stuff.
    Front shock on my monster wagon is welded on with it.
    been 2 years. And the welds are taking all the full stress or load.
    jack sunk into the stones a tin bit, wasn't allot, thought id just easy it back a bit to get it off. Sucker ripped the bolts for the shock out of the the A-arm.
    easier to weld then replace A-arm.
    Friend who has a super cheap flux mig, only 2 settings. [mine has 4]
    He built his own trans adapter out of some old clutch parts and a end shaft.
    What he was doing was putting 2 4 speed trans in his truck in line for a super mega range. Was neat shifting gears goin in reverse. He just stuck the 2nd one in 3rd for 1:1 ratio when not needed. He broke everything else but his flux core welded adapter.
  6. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    XVFinishes, what is the purpose of doing all that work on the tank?
  7. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    For the same reason the human body breaths on it own when unconscious while other mammals like dolphins must think to breath or they will die.
  8. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    You may have breathed in too many of those welding fumes.
  9. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    Oh and lets see what you have made then???
  10. Robert
    Do I hear a gauntlet being thrown?:)0)
    I would love to have a larger tank for more range. The XJ750 upgrade is easily done but I'd love to see other opitions and you, XV, have been the singular example of expanded capacity for an XJ that I have seen.
  11. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    There is a 5gal tank that bolts on to the Virago but they aren't cheap most times n ya also must change seats. The stock tank just doesn't hold enough gas.
    I was hoping for a 5-8gal tank in the end.
  12. kevineleven
    kevineleven Member
    Columbus, Ohio
    Junkyard wars!
  13. RickCoMatic
    Looks like your the man for the job!
    It takes a special touch. Looks like you got it.
    Let the limit of your imagination be your guide!
    I think I have a 900 Tank that is cut and beat if you need a cadaver!
  14. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    Yea it helps to have the stuff around for cheap or free so there is no real loss except free time. I often have moods that hit me and I jumble junk into new junk.
    check out this page
    BackYardAmericanChoppers.US
    Still working on that 3rd really low slung bike. Had to rebuilt forks several times to get it somewhat ride-able.
    The first two bikes ride or rode great out of the box so to speak.
  15. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    Another tip, most of them don't have cooling fans so your welding time is short till it shuts off. Add your own fan to cool it down and you can weld much much longer.
  16. Robert
    Thanks for the tip!
  17. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    That's the only difference I could find in the one I got. Its gas ready, 4 power settings and can do aluminum for about $150 less and only thing different is no fan with auto shut off when it get warm. [cause no fan it will auto shut off in just a few mins] Pricier one just has a fan, same auto shut off. Sure the fan makes them last allot longer. The auto shut off is a safety catch but it getting that hot often can't be good.
    still had the grill slots n screw holes for the fan in the back.
    got a good pancake AC fan from a surplus catalog store as I member ordering a ammo can with it and can weld all day long without it getting warm.
  18. willierides
    willierides Member
    NY
    Once you use the gas, you'll never want to use the flux core wire again. Very cool what you're doing there, xv! I bought my Maxim for the primary purpose of learning to weld and tinker. I did a bit of cutting, grinding and welding on this bike, but I didn't do any structural welding. That is, I didn't weld anything on this bike that will kill me if it breaks due to a bad weld. Sometimes I think I end up grinding off more than I weld on, especially until I get in a groove or get my settings just right. I have one of the cheaper welders, too. Four heat settings and a speed pot for the wire feed, cheap pressure regulator for the gas, just reverse the polarity when welding with gas vs. flux core. I will have to see if it has a fan, but it does sound like it now that you folks mention it. I know I've welded for a considerable time without it ever kicking off.
  19. XVFinishes
    XVFinishes Member
    Toledo, Ohio
    Naaa Id only use gas [I have gas, never hooked it up] if I get a Tig.
    They build ship with flux shielded wire. Thats all Arc welding is, the flux is just on the out side not in the center. Good multi pass flux core wire works just fine.
  20. 7DAYSLAVE
    7DAYSLAVE New Member
    SOUTH CAROLINA
    I have a licoln flux core and have no complaints just more spatter and slag to clean and grind-- going to buy a pony bottle and mig conversion kit when i get the cash
  21. schleht
    schleht New Member
    Los Angeles, California
    X2 (ditto)
  22. TIMEtoRIDE
    You got like 50 seams--how do you seal it all up and make it vibration proof and safe? I was thinking JB-weld or epoxy resin or that gas tank patch stuff. How much gas did it end up holding???
  23. 07spacker
    07spacker Member
    Utah
    am i a redneck because i arc-weld everything...? i never did like the wirefeed stuff... i've never done tig though
  24. TIMEtoRIDE
    If you paint everything you weld black, you might be a redneck.
    If you don't clean the slag before paint, you might be a redneck.
    If you spray the paint while the part is still hot thinking that you are baking the paint like powdercoat, you might be a redneck.
    If your girlfriend doesn't flinch while holding the part as you tack weld, then you're both definitely rednecks.
