1982 XJ750 J Maxim Flashers
Discussion in 'XJ Technical Chat' started by LeClairerog, Apr 24, 2017.
  1. LeClairerog
    LeClairerog 1982 XJ 750 Maxim
    LeClaire, IA
    I have a 1982 XJ750J and the flashers don't flash. Last year I replaced the front flashers because the ones a previous owner installed were not the correct parts and the flashers stayed on.
    However, the flashers still stay on. Should I go to the flasher relay next?
    check and clean relay make sure it is the oem relay
    make sure your bulbs are 27 watts
    when you say flashers stay on do you mean constant light no flash?
    also you may want to remove the control clean and lube it .
    use electrical cleaner silicone spray and dielectric grease
  3. LeClairerog
    LeClaire, IA
    Thank you. The bulbs stay on constantly.
    I'll address each of the issues you have mentioned.
  4. XJ550H
    relay cover can be popped off and contacts cleaned
    LeClairerog likes this.
  5. Timbox
    Not too sure how the front light ground on that bike? If you run a wire from a know good ground to the metal portion of the light fixture and it start to blink, then check the ground. Just did that on my CX500 front blinkers. Stayed on but would not flash....hope that helps.
  6. LeClairerog
    LeClaire, IA
    Thanks. I'll give that a shot.
  7. XJ550H
    remove the lens you will see a braid that grounds it to frame or it has 2 wires that go into the headlight bucket
  8. LeClairerog
    LeClaire, IA
    Great. Thank you.
