Valve clearances tighter than expected.
Discussion in 'XJ Technical Chat' started by REUBEN, Apr 28, 2017.
  1. REUBEN
    REUBEN 1985 XJ700N (NOT PICTURED) Premium Member
    Midwest United States
    This machine has not ran in over 12 years. PO claimed ran when parked and I have not seen anything to dispute this. Pulled my rocker cover and measured my valve clearances. All of my measurements were tight. I'm not a novice, but I want to be sure I'm not doing something foolish before I drop a large amount of money on shims. My results are shown on the picture. Assuming I do need to replace all 16 shims, where would I get them? I did not find a listing at XJFOREVER.
  2. k-moe
    That's not uncommon. Hardly anyone bothers with proper maintainance.
    Don't buy shims. Starta conversation with Hogfiddles. He runs a shim pool.
    You will most likely be able to swap at least somE of the shims. Start pulling them one at a time and make a chart of what is currently installed.
    Chacal (XJ4EVER) does carry the shims if it happens that Hogfiddles does not have the shims you need. Just start a conversation with him for prices.
    Stumplifter likes this.
  3. REUBEN
    Thanks K-Moe.
  4. hogfiddles
    You can always forward your measurements and current shim sizes to me and I'll doubt-check your figures for you......and we'll check the pool , too
  5. Toomanybikes
    Tsawwassen bc
    A question for you. Have you found that early non YICS engines have had fewer valve adjustments due to paper pain in the butt valve cover gasket?
  6. k-moe
    The only data I have is posts from forums. I Have not done enough of each type to draw conclusions based on personal data collection.
    What I see is that roughly 70% of motorcycle owners just get on and ride. Nothing gets done until the bike stops working, then it gets sold or parked for a decade.
    I can't see how gasket type makes a difference in decision making, but it could be possible.
  7. XJ550H
    at 33$ a pop from the dealership I can see some cheeping out on the gasket. if it is glued down on both sides you would have to replace it every time you checked the valves.
    Picked up a running parts bike and the seller states" listen how quite the valves are you can't hear them ticking"
    I imagine the valves are all tight not a single tick. I shut it down and pushed it onto the trailer.
    cgutz likes this.
  8. Toomanybikes
    Tsawwassen bc
    Reason for the question is that all 3 of the early xj's in the driveway have never had the screws touched. I'm going to open them up soon and check valve clearance
  9. REUBEN
    Thanks Hogfiddles.
    Is it normal for the clearance to shrink? I had assumed normal wear would cause the clearance to grow! Does the valve stem stretch?
  10. k-moe
    Remember that there is no rocker arm in this valvetrain. The valve seat slowly recedes further into the head as the valve pounds into it during normal use. The result is that valve moves closer to the cam, reducing clearance.
    hogfiddles likes this.
  11. REUBEN
    Ahh. Didn't think of that. At least my wear seems to be somewhat even.
  12. hogfiddles
    Exactly.
    For airheads the interval is about every 5000 mi to check. The X (and the FZ with the waterh-head Genesis engine) have a greater mileage span.....thankfully......it's a much more involved process.
  13. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I bought my XJ550 new. Paid for dealer to check and adjust valves at 5k. Went another 18k before next check (before I found this site) and half were still in spec. 3 slightly out of spec, 1 dangerously tight.
  14. hogfiddles
    That's why it's a CHECK :)
    kind of like your 'now that you've turned 50 yrs old' colonoscopy. It's a REALLY good idea that it's CHECKED. Doesn't mean that something bad WILL be found, but If anything IS not right, it can be removed and get your proper clearance back BEFORE anything gets too close.
    k-moe and Toomanybikes like this.
  15. REUBEN
    Is it safe to rotate the engine with the valve shims removed?
  16. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    NO! the edges of the bucket can damage the cam surface.
  17. REUBEN
    That's what I figured.
  18. hogfiddles
    Don't do that------
  19. k-moe
  20. REUBEN
    Finally read the how to post on airhead valve adjustments and all of my questions were answered in that thread. This site is really something else. NEVER GO TO FACEBOOK. Seen a few good forums die off that way.
    Stumplifter, TheCrazyGnat and k-moe like this.
  21. k-moe
    The XJ Owner's Facbook group is pretty solid. Some of us are on there too.
  22. hogfiddles
    Ever.
    Except for XJOG
    TheCrazyGnat likes this.
