1980 xj650 carb - geez!!!
Discussion in 'XJ Technical Chat' started by hogfiddles, Apr 30, 2017.
  1. hogfiddles
    I'm in the process of rebuilding a rack for a 1980 Maxim-I for a member. It came with two other racks for putting one together from the three. The best one seemed to be a midnight rack... it tore down beautifully---until carb 4 mixture screw was so seized I had to send it out for extraction. Well, the screw came out and brought half of the threads with it as they were severely eroded. The screw falls almost all the way down in. It was worth the attempt, but that body is junk now.
    So onto the original rack--- it tore down easily enough, except carb 2 has a broken float tower. Well---I have a 1980 maxim-I with a super-low serial # as a resto project. So.... break THAT rack for the #2 carb. That rack is in rough shape, but the casting is good, soooo.......
    Opened it up to find a very green world. Fortunately it all came apart withou much trouble until the fuel valve...
    Follow along--
    The float was SO corroded I had to break it away from the pin, AND the pin was so corroded that I had to cut it just shy of the towers. LOVE my dremel cut-off wheels!
    Of course, the fuel needle was seized in the bore.....
    But I got it out
    Then... the first time EVER to have a fuel valve body refuse to come out. What you can't see is the tip of another easy-out that broke inside!! I had to use a big clamp to anchor the body, a bigger easy-out and a big vise-grip..... and a lot of Kroil--- and my micro- torch to heat things a bit.
    It came out.... good thing--- now all of whatever THIS is can come out. I STILL have to get the float pin ends out of the towers.... obviously with out breaking a tower----
    A lot of careful application of: heat, kroil, a fine point nail-set, and a good support for the tower..... and 45 more minutes of careful work------
    Finally it's ready to start getting cleaned up.
    GEEZ!!!
    wgul, af226, Stumplifter and 2 others like this.
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I don't see a problem I see a highly experienced and skilled person at work who loves what he does.
  3. OldFleetGuy
    OldFleetGuy Member
    Eastern North Carolina
    Wonderful music will also envoke tears of joy...
    Stumplifter likes this.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Nice work Dave, I would have given up long before.
  5. chacal
    It's the world of Shrek.
    BTW, those 1980 float bowls have removable starter circuit jets, they unscrew out of the bowl like any other, designed-for-human-beings type of jet would do, why Hitachi changed that beautiful feature is beyond me.............but then again, most things are.
    Ian Vanore likes this.
  6. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    nice job
  7. hogfiddles
    Well- well- well.....a lot of work, buts it's a good-'un now :)
    af226, TheCrazyGnat and Stumplifter like this.
  8. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Those look like they were dug up in your backyard. :p:D
  9. Xjrider92117
    San Jose Ca
    And of course they look new now... Very nice work!
  10. Toomanybikes
    Tsawwassen bc
    Getting to know Dave , a carb will never get the best of him
  11. OldFleetGuy
    OldFleetGuy Member
  12. Ian Vanore
    Ian Vanore Member
    Philadelphia, PA
    This is photoshop -- he can't be that good.
  13. hogfiddles
    Ian Vanore and k-moe like this.
  14. XJ550H
    that good and humble too.
  15. Toomanybikes
    Tsawwassen bc
    image.jpg They start like this more often than not. And Hogfiddles has seen more than his share.
  16. hogfiddles
    ....and worse---
    Toomanybikes likes this.
  17. wgul
    wgul Active Member
    Boston
    Beautiful work Dave. Thanks for showing us
  18. hogfiddles
    You're welcome!
  19. Jetfixer
    hogfiddles is da man!!! I once tore down my carbs on my 82 Virago jets looked like peanut butter , but no where as bad as those carbs !!!
