Oil Leak from the Turbo/Exhaust
Discussion in 'XJ Technical Chat' started by Masterx, May 4, 2017.
  1. Masterx
    Masterx Member
    Southern New England
    Went to go take my bike out this morning and noticed a puddle of oil beneath my like and a leak between my exhaust and turbo. I know it's not much to go on, but is this a gascket that got blown? Or what exactly? Any thoughts are appreciated.
    For better clarification, I circled the area I photographed.
  2. Masterx
    Masterx Member
  3. Metalliccurrent
    Metalliccurrent Member
    OHIO
    I'm not familiar with turbo on this bike but I have 15+ yrs experience with heavy truck turbo diesels. The gasket circled seals exhaust gasses only. I would guess that either the turbo is going bad or engine is pushing oil out exhaust(more likely turbo). Be carful with this issue, I can't count on one hand that amount of times I've seen a turbo fail and take a engine with it or cause a fire. Most if not all turbo's don't have a oil seal like a engine, It's more like a piston ring on the turbo shaft. A normal rubber seal cant take the high RPM and heat/pressure. That being said sometimes a exhaust or intake leak will cause oil to seep around seal ring because of pressure differences. Hope this unfortunate info helps you. Sorry for the bad news.:(
  4. Masterx
    Masterx Member
    This is some major bad news if you're right. I just had the Turbo unit replaced back in February which is even more disappointing.
    On another note, I should be fine to disassemble that leaking part by removing those bolts?
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Pardon the side track - I know nothing about turbos (car, truck, motorcycle).
    I always ass-u-med they were an intake 'boost' - this is clearly on the exhaust side of the engine.
    What does it do and how?
    Ass-u-ming again - the exhaust gasses go in and the turbo some how increase the velocity of 'escape' which pulls the exhaust out of the engine faster . . . .? ? ? ? :confused:
  6. Masterx
    Masterx Member
    Pretty much. It's where the exhaust pipes dump into the turbo, and there is oil seeping from it. I know nothing about turbos either, but as far as I know there shouldn't be oil coming out of that end.
  7. Metalliccurrent
    OHIO
    Glad you asked. The turbo has a intake side and a exhaust side. Inside each housing is a fan or turbine. As the exhaust gas leaves engine it spins exhaust fan which is coupled to intake fan by a shaft. The intake fan spins and starts to build pressure in the intake manifold(boost). Now there is ALOT of theory and math involved with size of the turbines. Which all boils down to how fast the turbo "spools up" and starts making boost and how much boost pressure it makes. I've attached a pic for your viewing pleasure. Yes, you should be able to remove the exhaust pipe from turbo and determine where oil is coming from. Either upstream or down stream of turbo. Was this turbo rebuilt or good used one? Most of the time turbo's can be rebuilt as long as the turbine or housing isn't damaged. It's pricy thought.
    Stumplifter likes this.
  8. Masterx
    Masterx Member
    Thanks for the explanation.
    It was one of the rebuilt units from XJ4ever.com. I am just amazed that it let go after only a handful of rides. (If that is indeed the issue.) I tried removing the bolts but they are on so tight and it's an odd angle, so I couldn't get anywhere.
  9. Scorpion1016
    Scorpion1016 Member
    I have a little experience with Turbos and it may not be the turbo make sure all breather hoses are clear excess pressure can cause oil to be sucked into the turbo. Fixed a car that used 4 quarts of oil every 5 thousand miles by cleaning hoses and breather system so start with the free and simple then go to the more expensive
  10. Stumplifter
    near Irma, WI
    m'kay - but what is the theory of enhanced performance?
    Quicker air exchange = cooler air = better combustion?
  11. k-moe
    Stuff more fuel and air into the combustion chamber and get a bigger boom. It's the equivalent of increasing displacement without needing to increase displacement.
    Metalliccurrent and Stumplifter like this.
  12. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I have a Turbo in my garage waiting for some exploratory surgery. There was excess oil in the turbo (exhaust) smoking out the neighborhood, that is what the previous owner told me.
    I've read a bit about what can cause this. The 1st place to look is the check valve located at the bottom of the motor in the oil line feeding the turbo. When this fails excess oil continues to pool in the turbo unit when the bike is sitting. If working properly it shuts the gravity feed of oil off when parked.
    Metalliccurrent likes this.
  13. dkavanagh
    Rochester, NY
    I've had a bunch of turbo cars. Turbos have an oil jacket to keep those bearings cool and moving nicely. There are oil seals to keep the oil where it needs to be (and out of the turbine and compressor housings). I would not expect to need to shut off the oil flow to the bearings. What I suspect if you're blowing oil is that either it's hitting the engine internally (and you'd be burning it), or it's leaking in the turbo, in which case, it might not burn, but would certainly smoke a lot!
  14. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    it's pressurizing the intake air. It's not speeding up the exhaust air, in fact the pressure of the exhaust air is what's driving the shaft that powers the intake compressor.
    Instead of being just atmospheric pressure (actually a bit less, as it's drawn into the engine via vacuum), the turbo forces more air through the carbs and into the combustion chamber.
    What's fun with turbos is the way it spools up. You crank open the throttle, bike draws air, booms it, forces it out the exhaust. Exhaust pressure spins the turbo, which adds even more air. Bigger boom, more exhaust pressure, more spinning, more intake pressure.
    As Metalliccurent (who knows way more than me, I'm just a dumb guy who likes zoom) said, a lot goes into determining just how much pressure your engine can handle, how quickly it can build that pressure, etc.
    There's lots of fun videos on YouTube where people push the boost pressure up beyond what the engine can handle. It ranges from disappointing to really, really dramatic, depending on what fails first.
  15. Simmy
    The seals in the turbo are like piston rings and will leak oil, they have to or they'd seize. Yamaha mounted the turbo below the motor and without that check valve the oil will continue to run into the turbo when parked.
    I'm not saying that's the problem but it's the 1st place to look for sure, it is a known problem area. The inlet flange to the turbo is obviously leaking also so it will need to be redone with a new gasket.
  16. dkavanagh
    Rochester, NY
    That's interesting. Not used to a turbo mounted so low.
  17. chacal
    Yes.
    Yes, again.
    While a clogged/non-performing oil supply valve (front of crankcase, just off the side of the oil filter housing) is the main cause of an oil leak such as yours, there is also a pair of copper crush washers used at the turbocharger itself, for the oil supply pipe, and a paper gasket for the oil supply return pipe.
    And although possible, it is doubtful that the burned exhaust collector output-to-turbo input gasket, shown in your photo, is the source of the OIL leak (although, if it very OILY at that leak point......on the collector itself.....then that is also a possible issue).
    Our rebuilt turbo units carry a warranty, so if the internal piston ring seal has failed, of course it will be repaired for you. However, when that seal fails, normally it blows oil out of the exhaust (while running) like nobody's business......
  18. Masterx
    Masterx Member
  19. chacal
    Yes, but you won't need to replace it, you need to remove it and carefully clean it up/out..............there is a small fine mesh screen in there (called the "strainer" as well as a spring-loaded ball (that's the "check-valve" function) in there, and you want to be sure that is not seized due to junk/gunk/residue/demons of any sort.
  20. Masterx
    Masterx Member
    Alright. So I'm going to drain my oil and attempt to clean out the relief valve. Anyone have recommendations for motor oil to use? I noticed that the Seca Turbo service manual states Yamalube 4 cycle sae 20w40 type se motor oil but I am only pulling up marine outboard and a transmission oil on amazon. Even a search on shop yamaha comes up with the marine oil. Any help is appreciated.
  21. Simmy
    I believe Yamaha badge their oil as 20W40 to trick people into buying Yamalube. I know of no other brands labelled like that. Yamaha don't make oil, just re-badge a 3rd party supplier.
    Find a good 20W50, in England a 10W40 I think would also do. Lot's of people warn about certain specs and I used to abide by that. Now I just use good car oil. Change it often and it probably wont matter.
    Some have had problems with the starter clutch related to some oils, swear that others slip their clutch, I don't doubt it might be so, just not my experience.
    I'm skeptical of anyone who claims to feel a difference in performance of one oil to another.
  22. chacal
    Engine Oils:
    Which type and brand should you use? Great question! Here's a bit of an answer:
    http://www.motorcycleproject.com/text/motoroil.html
    NOTE: Yamaha specifies the use of API "SE" or "SF" grade oil in all XJ models, but that is based on the original (at that time) automotive motor oil standards.....which, as the above article notes, are no longer valid in the current lubrication industry environment and classifications. Therefore we recommend that the oil you choose should meet or exceed the JASO "MA" duty rating, and all of the oils below exceed that standard. Do not EVER use synthetic oils unless they are specifically designed for motorcycle engines using wet clutch systems (as these bikes do use), as you will end up with a slipping clutches (both drive clutch and especially the starter clutch). Additionally, do not use "automotive" grade oils that have friction modifiers (reduced-friction additives) as these will cause the same problems.
    The factory recommends the use of 10W30 oil when the outside temperature will never exceed 60-F, or 20W40 if the outside temperature is always above 40-F. Unfortunately, 20W40 oil is difficult to find anymore, but there is not an issue with using a straight 40W oil, or 10W40, 15W40, or 20W50 formulations instead.
    All XJ-series engines require somewhere from 2.5 quarts to 3.0 quarts for an oil change (depending on whether the filter is replaced or not) except for the 1100 engines, which require slightly under a gallon to accomplish an oil and filter change.
  23. Masterx
    Masterx Member
  24. Wintersdark
    This frustrates me. If the temp doesn't exceed 15C, or is always above 5C (after conversion)... That's a 10 degree gap.
    It was snowing here and -10 last week, it was 26C here today. It'll probably be below freezing again several times before summer, and even in the summer it'll often be cold in the mornings and sometimes freezing, while 30+ in the late afternoon.
    I try to split the difference and run 15w40, but... grrr. Stupid physics; stupid Calgary weather.
  25. Masterx
    Masterx Member
    Changed the oil on the bike, drained it out, new filter, cleared out the relief valve and put it all back together. Was a pain with removing the front exhaust but I got it all off. Been a day since I did that and so far no more oil. I've rode it about 50 miles and there have been no issues... fingers crossed.
  26. Masterx
    Masterx Member
    Well it's Friday and I've taken the bike out to ride and kept an eye underneath the bike for any new oil leaks. Everything looks good so far. So I am going to assume that it was the check valve. Thanks to Simmy for bringing this potential diagnosis to my attention!
  27. Masterx
    Masterx Member
    Hi Again. It seems my Turbo is back to the same issue.
    It's been a good two or three weeks since I've taken it for a ride, and I noticed just today that the spot beneath the bike is once again covered in oil and it seems to be dripping from the exhaust/turbo joint mentioned above. I tried the check valve before and that stopped it. Might that be related to it once again? Or am I looking at a possible other issue? Thanks in advance.
  28. Toecutter418
    Toecutter418 New Member
    Atlanta GA
    All XJ-series engines require somewhere from 2.5 quarts to 3.0 quarts for an oil change (depending on whether the filter is replaced or not) except for the 1100 engines, which require slightly under a gallon to accomplish an oil and filter change.[/QUOTE]
    So what are your thoughts on Yamalube Semi or Full Synthetic oils for the Seca Turbo?
  29. Simmy
    The Turbo should have oil changes more frequently than the normally aspirated bikes, therefore I wouldn’t waste money on synthetic.
    Yamalube conventional should be good
  30. Fuller56
    Fuller56 Well-Known Member
    @Simmy, was there not an issue with oil draining into the turbos that was fixed by putting an inline check valve on the oil return line from the turbo? The one I had for awhile had previously had this done. Something similar to dry sump bikes "wet sumping".
  31. Simmy
    Yes, there is lots written about the OEM check valve in the feed line seeping oil at rest.
    I found the oil seeping past the sealing surfaces in the scavenge pump and like yours, also installed a check valve there.
    So a check valve is needed on the feed line to the turbo and another from the turbo, much cheaper than replacing the oil pump.
