Edmonton XJ Owners
Discussion in 'Western US and Canada' started by TrevorZ, Aug 30, 2014.
  1. TrevorZ
    TrevorZ New Member
    Edmonton
    Hi all I see that there are some old threads for Edmonton riders but nothing that has been updated for quite a while. I am looking for anyone in the Edmonton area who my be able to help with me with some of mechanical issues with 81 XJ750 SECA. I am not the mechanically inclined but would like to learn. Let me know!!
    Trevor
  2. FlyingSkull
    FlyingSkull New Member
    Edmonton,Alberta,Canada
    HEY Trevor I might be able to lend a hand. I am also local so what seems to be the problem?
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Hey, Flying Skull... just a little pointer. If you click on a poster's name, a window will come up with their info. Trevor hasn't been on the site since Sept. of last year. You may not get through to him. Some folks just don't stick around. Awesome that you're willing to lend a hand, though. Wanna fly to Ontario and clean my carbs? lol
    XJSixfifty likes this.
  4. RollinHeavyD
    RollinHeavyD New Member
    An Igloo In Canada
    Im located in the depths of Mill Woods. I am pretty handy but there isnt enough time for all the projects in my life.
  5. FlyingSkull
    Hello Rollinheaveyd, welcome to the forum, I am not far from you as I am just over by Ellerslie school.
  6. RollinHeavyD
    An Igloo In Canada
    Well if I can get either of my bikes working we should meet up and go for a rip.
  7. Jiggs the Geezer
    Jiggs the Geezer New Member
    Alberta Canada
    It Jiggs, I'm in the country southeast of Edmonton, but when I "go to town" its to Edmonton. My XJ750 midnite maxim is ugly hard to start, floods easily, and once flooded I have to take the plugs all out and heat/dry them up with a mini-torch and put them back in, then it will start and burble and burp for a bit then once it warms up it seems to run pretty decent. At least decent enough to leave a 750 shadow seriously in the dust... I'm going to replace the plugs again, any recommendations other than NGK BP7ES? Thanks, Jiggs.
  8. chacal
    Might be time for a carb rebuild.........!!
  9. need2speed3
    need2speed3 Member
    Spring has arrived in Edmonton. The birds are frisky and the Harleys are making noise on Whyte Ave.
  10. AxeMatt
    AxeMatt New Member
    Drayton Valley
    RangerG and need2speed3 like this.
  11. need2speed3
    need2speed3 Member
    Sweet, that looks like new! What is the mileage? I fitted a chrome front fender to my 650 Seca for the classic look, having admired the 550.
  12. XJ550H
    Nice touch with the fender
  13. AxeMatt
    AxeMatt New Member
    Drayton Valley
    It's got a bit over 50,000 kms. I don't know who did the restoration a few years back but I'd buy a beer for sure...it's almost mint
  14. Jiggs the Geezer
    Alberta Canada
    Its Jiggs again, my XJ750 midnite maxim is still starting very very hard. Local dealer says intake valves may be out of adjustment, clearances tightened up and valves slightly open, causing low compression, improper vacuum, and thus difficult starting. Estimate for bucket-shim valve adjustment is 4-6 hrs or $600-$900. Ouch. I'm a relative rookie on fixing motorcycles, I've swapped engines on Subaru and VW cars. If I have a shim assortment kit, would valve adjustment be beyond a reasonbly competent wrench monkey? Or are there other less complicated possible causes of hard-starting I should eliminate/fix first? Carbs like these are something of a mystery to me, I've never had them apart, maybe its time...
    Any advice welcome.
    Thanks, Jiggs.
  15. FrostyDog
    FrostyDog Member
    Canada
    Hey if I were to bring my maxim up would anyone mind giving me a hand on an odd weekend getting her to run and start properly? And as a side note, if anyone needs parts for a seca or maxim there's a great shop in the north for used parts.
  16. FrostyDog
    FrostyDog Member
    Canada
    It's not too bad to do. If you want I can give you a hand with it. I should be free most nights now that class is done
  17. need2speed3
    need2speed3 Member
    OK, anyone up for a GTG at Hawrelak Park? Summer is calling...
  18. Perky
    Perky New Member
    Alberta Canada
    If I could get my bike to start I'd be al over that but it looks like a summer of greasing around for me trying to get my 84 xj11 00 up and running
    need2speed3 likes this.
  19. FrostyDog
    FrostyDog Member
    Canada
    I know the feeling all too well. My 550 has been laid up in a friends garage for a couple months now. No clue what the bloody issue is with it. Replaced the old fuse box and now the thing MIGHT start.
  20. Perky
    Perky New Member
    Alberta Canada
    Well good luck I wish ya the best lol I just bought mine and it didnt start when I bought it so I really have no clue what the issue will be I barley know where to start lol
  21. FrostyDog
    FrostyDog Member
    Canada
    Did you check the valve clearances and compression? Good place to start there. I always start with the big 3: fuel, air, and compression
  22. Perky
    Perky New Member
    Alberta Canada
    I just recently emptied the tank to try and get rid of the old fuel I cleaned out the air filter and that's about it so far spark plug check was next and compression check after that
  23. Eurotas
    Eurotas Member
    Edmonton
    Which shop?
  24. FrostyDog
    FrostyDog Member
    Canada
    Edmonton cycle salvage. Apparrently the owner is selling it to his son soon
  25. Eurotas
    Eurotas Member
    Edmonton
    Hmm I need some side covers
  26. Mathius
    Mathius Member
    Alberta
    Edmonton riders eh..
    I'm up in GP, and I just joined the forum for some info on my 82' Maxim 750.
    I'm always on the look out for good used parts in Alberta. Any leads on places north of Edmonton?
  27. need2speed3
    need2speed3 Member
    IMG_4140 small.JPG IMG_4139 small.JPG Not too many more riding days left :(. Just 8 deg. C this morning in YEG. Made the fall pilgrimage to CDN TIRE for fuel stabilizer :eek:.
    RangerG, AxeMatt and Alan63 like this.
  28. chacal
    Nice looking bike!!
  29. Mathius
    Mathius Member
    Alberta
    Snowed here yesterday. It didn't stick though...
  30. need2speed3
    need2speed3 Member
    Riding days are still here!
  31. af226
    af226 Member
    Kingston, ON
    Edmonton cycle salvage has a tonne of maxim and seca bike in various stages of breakdown. I went upstairs looking for a kick-start for a vintage dirt bike project and WOW. Bring a good flashlight though. They are not overly helpful but if you know what ur looking for and what it looks like they have what u need.
    AxeMatt and need2speed3 like this.
  32. need2speed3
    need2speed3 Member
    Any recs for a competent shop in Edm that can do a tune up at a reasonable price? The guy I used six years ago is gone now.
  33. kempertime
    kempertime New Member
    Edmonton, Alberta
    Did you end up finding anyone?
  34. need2speed3
    need2speed3 Member
    new seat B.jpg Sorry for the late reply but with winter comes thoughts of skiing :rolleyes:. To update, I did find a great shop in Sherwood Park called Sherwood Motorcycle. They stripped, cleaned, and sync'd the carbs, installed one bigger main jets, and now it runs great.
    One small hiccup, while stored outside in their lot a gust of wind blew something metal down on my seat and left a large cut. We negotiated a price and I had it recovered in cafe style. Not too sure about the result :oops:.
    PS. Have others heard the noise crackdown planned for Edmonton next year. Apparently they are piloting a noise camera which will mail tickets like photo radar :confused:. Actually I'm over the loud drone of my megaphone pipe and have ordered a muffler packing kit to tone it down.
    RangerG likes this.
  35. CARMEL ALCANTARA
    CARMEL ALCANTARA New Member
    Edmonton, Alberta
    Hey guys! I am new to this group and I live on the west end, Callingwood area. I just had my 1981 SECA 750, and was able to clean the carb
    and so now I am looking for somebody who could do a tune up on my bike. Anyone here who can give me a hand?
  36. Franz
    Franz Well-Known Member
    Scotland UK.
    Nice 650 Seca.
  37. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I just did rings, valve seals and cleaned up valves and seats on my’81 Seca 550. 79,000 kms, only 50 since rebuilt but it seems to running stronger for sure.
    In Lloydminster and parked for winter. B25F3CDB-A9C0-49A3-93BF-2CF2AD6EB774.jpeg
    chacal likes this.
  38. Marchy
    Marchy Member
    Canada
    In Calgary about to buy 84 750 going full tare down built bike lift the the occasion
