Gauge cluster noise
Discussion in 'XJ Modifications' started by Gohnmad, May 9, 2017.
  1. Gohnmad
    Gohnmad New Member
    St. Louis MO
    Hello, does anyone know how to repair a noisy gauge cluster? All gauges work but is noisy and sounds like a box of rocks while riding. 82 xj550 seca.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  3. Gohnmad
    Gohnmad New Member
    St. Louis MO
    Thank you, I will give this a try.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    One tip, if you use brake cleaner or anything similar prior to lubing be very careful where it goes. Those gauge faces and odometer wheels are extremely sensitive and even a little bit of overspray will damage the paint etc.
  5. Gohnmad
    Gohnmad New Member
    St. Louis MO
    Thank you, excellent advice.
  6. Gohnmad
    Gohnmad New Member
    St. Louis MO
    I have also found my brake caliper loose where the pad pins are.
