Diode block values
Discussion in 'XJ Technical Chat' started by rustysavage, May 15, 2017.
  1. rustysavage
    rustysavage Member
    Belvidere
    Can anyone please point me in the direction to find the values of the diodes in the block of a 81 550 maxim. Please and thank you!
  2. k-moe
  3. rustysavage
    rustysavage Member
    Belvidere
    I read thru the write up and saw the location and wire colors... But I didn't see the values of the 3 diodes and 1 resistor.
  4. k-moe
  5. XJ550H
    the values are listed as well as the part numbers for diodes
    8.2 Ohms 5%
    i would use the 1N5402 diode instead of the 1n4001 for the higher amp and voltages
    photos are for showing oil light system using diode and resistor.
    resistor goes to oil bulb.
    the common end of the diode and resistor goes to oil level switch.
    cathode end of diode goes to starter/solinoid connection to test light on pressing the starter button
