Float Level Check Warm or Cold?
Discussion in 'XJ Technical Chat' started by Ass.Fault, Oct 16, 2007.
  1. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Should the levels be checked while warmed up, or cold?
    Or does it even matter?
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Doesn't matter!
  3. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    I'd check them cold to avoid burns.
    Also when the carbs come off (for float adjustment) some gas could spill on a hot engine and.............. well it's anybodys guess.
  4. Ass.Fault
    10-4
    did not think of that.
    burn baby burn
    thanks for the quick replies.
    Will let u know the results soon, maybe tomorrow
  5. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    The float level is given with a (quite large) + or - as close enough is close enough, though all 4 levels should match each other as best as you can. The + - tolerance would also negate any slight difference caused by changes in temperature.
    Care should aways be used when fuel and hot engines are involved.
  6. Ass.Fault
    Re: Float Level Check Results
    Results of the test
    1&2- 5mm
    3- 6mm
    4- 5 1/2 mm
    Bike was cool to the touch.
    Carbs are Miks I think
    Bike on centerstand.
    Fuel line was very long ( about 2-3 feet )
    and measure from the middle of the fuel bowl( out side bowls 1&4)
    There looked to be a slight diff between the air cleaner and engine sides of the bowl.
    The levels seem low. 3mm +/- 1mm is spec. They are relativly simmilar though
    Any advise?
  7. MBrew
    MBrew Member
    Ft. Worth
    I'm only familiar with the Hitachi's so that's all I can comment on. They do seem low. After changing the needles and seats my bike wouldn't run, but they were much lower than yours.
    You don't mention why you thought they needed checking in the first place, but for my money, if the bike is running decently l wouldn't mess with them.
    If it's faltering, and I would expect that mostly under acceleration, I would.
    Engine temp won't make a difference, but theoretically fuel temp could. I doubt that with the small volume we're talking about that it would make as much as a mm difference, but I guess it's possible. I'm impressed you could see a 1/2 mm at the odd angles we have to look at these things.
    Good Luck,
    Mike
