carb boots
Discussion in 'XJ Modifications' started by desmotom, Jun 5, 2017.
  1. desmotom
    desmotom Active Member
    Canada MB
    I made these for my wife's bike to replace the stock rubber ones. Silicone hose or rubber for the connection to the carbs? I've heard mixed thoughts on silicone and fuel. IMG_2512[1].JPG
    Taylo105 likes this.
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I'm not an expert, but I think they are made of rubber so they can flex as needed when the engine moves around. The intake and carb boots provide the mount between the engine and the airbox, hence the need to be flexible. If you are running pods, it may not be an issue.
    The metal ones sure a pretty however.
  3. k-moe
    Rubber hose, fuel and oil resistant.
    desmotom likes this.
  4. XJ550H
    nice but are you going to put vac ports in them?
  5. desmotom
    Canada MB
    Ports are on carbs...
  6. hogfiddles
    What kind of carbs? What bike?
  7. desmotom
    Canada MB
    K
    KZ440 ltd. I would like to make a set for my 650rj but a little more work with the ports and they have a slight angle toward cylinder head
  8. hogfiddles
    The 650rj carbs don't have vacuum ports, so those would need to be on the manifolds...
  9. desmotom
    Canada MB
    best way to cut large dia rubber hose...clamp as guide
