Bills 82 seca 750.
Discussion in 'XJ Technical Chat' started by Bmgalena, Jul 15, 2017.
  1. Bmgalena
    Bmgalena Member
    Joplin
    Starting to try and keep all my questions in one place:). To start does anyone know if the ignition switches from other xjs will fit on my seca? Thank you
  2. steber
    steber Active Member
    Scranton, Pennsylvania
    Nothing to add but glad to see you keeping the bike! Good luck.
    Bmgalena likes this.
  3. Bmgalena
    Bmgalena Member
    Joplin
    Got her going and took it for a ride around the neighborhood. First time i have been able to ride in months. Feels great
  4. XJ550H
    there are 2 types of switches 3 wire and 5 wire (atari style) 3 wire has a shorter bottom 5 wire has longer bottom mount but the black lock towers are the same so you can swap them if needed.
    all the xjs that have 3 wires will interchange and you can always swap the lock cylinders if needed.
    read this how to
    Clean and lube the ignition switch
  5. Bmgalena
    Bmgalena Member
    Joplin
    So dumb question. Are the rear bulbs on a seca supposed to be dual filament?
  6. chacal
    The rear brake/running lights bulbs should be dual-filament (1157 style); the rear turn signals are single-filament (1156).
  7. Bmgalena
    Bmgalena Member
    Joplin
    Thank you very much
  8. k-moe
    No such thing exists.
    Stumplifter and Bmgalena like this.
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Whut?
  10. MattiThundrrr
    Now for the serious questions:
    Is the bike in your avatar your 750? Where did the headlight and gauges come from? A 650? I like it!
  11. Bmgalena
    Bmgalena Member
    Joplin
    Thank you. It is my bike. The headlight was just something a buddy had laying around. Off a cb750 i think. Thats an old pic though. I wrecked it on railroad tracks so it looks a little different. Its now ice white with a ton of metallic flake.
  12. Bmgalena
    Bmgalena Member
    Joplin
    Anyone have opinions on after market speedos. Ie. Mechanical vs digital read?
  13. Bmgalena
    Bmgalena Member
    Joplin
    What is this?
  14. TheCrazyGnat
    Central PA
    Cam chain tensioner.
  15. Bmgalena
    Bmgalena Member
    Joplin
    Ahh
  16. Bmgalena
    Bmgalena Member
    Joplin
    Could someone post a pic of there speedo drive. Im not real sure how to get this new cable on. Will i need to take the wheel off?
  17. Bmgalena
    Bmgalena Member
    Joplin
    I figured it out lol. But i think the drive gear is shot. I can spin the cable on the speedometer side with it full seated
  18. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    I had a Yamaha RS100 with a hub driven speedo gear that, upon review of the parts fiche was missing a single washer on the axle assembly that kept the gear engaged with the cable. This washer, I'm sure son PO lost it when changing a flat and never thought it was a big deal.
    XJ550H likes this.
  19. k-moe
    There are ears on the speedo drive that have to slot into the wheel hub. If misaligned, the ears get bent and the speedometer drive no worky. The other possibility is that the cable is broken. It can be removed from the sleeve, checked, cleaned, and re-greased. Do that before pulling the wheel to check the speedometer drive.
    Speedometer drives are stout internally, but parts are still available if something has broken.
  20. Bmgalena
    Bmgalena Member
    Joplin
    I will check that out k-moe. Its a brand new cable so thats not it lol.
  21. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    There's a clutch washer that should be in between the wheel and the speedo drive. It's got two little metal tabs that stick out and engage the wheel and the speedo drive - one of the tabs on mine had broken off, causing the problem you describe. It's easy for this to happen if you take the wheel off (for example to change the tire) and don't take care to get the tab into it's slot when putting the speedo drive back onto the rim. Really, REALLY easy mistake to make, and that tab just breaks off or folds flat when you put things back together.
    The upside is, Chacal has them for pocket change, so replacing that clutch washer is trivial.
    Well. I see k-moe already answered. That'll teach me to answer a day old thread before scrolling down a teensie bit. Ah well =)
  22. Bmgalena
    Bmgalena Member
    Joplin
    So i got a new starter solenoid the other day from ebay. Worked great when i put it on but after a few starts it quit working. Any ideas on what could cause that before i go and get a new one and fry ot also.
  23. k-moe
    Is the battery charged?
    Will the solenoid click of you apply 12V directly to the control side (small wires)?
  24. Bmgalena
    Bmgalena Member
    Joplin
    Battery is charged. I will jumper the wires when i get home. It will start if i use a screwdriver to cross the posts.
  25. k-moe
    OK. So it's either the solenoid, or something upstream of the solenoid. Let us know if she spins the starter by jumpering the coltrol side of the solenoid.
    Have you used the kickstand lately?
