What do you need to upgrade a xj650h maxim 1981
Discussion in 'XJ DIY How-To Instructions' started by ricardo anaya, Jun 21, 2017.
  1. ricardo anaya
    ricardo anaya New Member
    2216 dobern Ave
    I need help on this one xj650 maxima 81 I broke a piston ring and one off the head velve cover its stock so what shud I do in this case
    you could find another motor a 650 or a 750 motor. if you get a 750 motor you will need the tci for it and rejet your carbs
  3. ricardo anaya
    2216 dobern Ave
    Well I got another bike it's a xj550 maxima 1981 what's the difference of xj650h maxim 1981 to a xj550 máxim 1981
  4. Toomanybikes
    Tsawwassen bc
    Very different engine configuration. Won't fit!
  5. XJ550H
    about 100cc and shaft drive instead of chain drive and bike weight
    it would not be worth the effort to swap the motors if that is what you are thinking
    but the 550 is fun to ride while you look for another motor
  6. Toomanybikes
    Tsawwassen bc
    Hi Ricardo
    Is the xj550 a parts bike?
  7. ricardo anaya
    2216 dobern Ave
    Ok the problem that I noticed was that the starter was working but it didn't crank the motor to start so I Took off the starter and I noticed the ⭐️ that the starter connect to its loose in the giver has no chain and the clutch it's loose to what should I do
  8. ricardo anaya
    2216 dobern Ave
    Yeah it's
    yeah the xj550 is for parts you need something from it
  9. Toomanybikes
    Tsawwassen bc
    Yea one of the guys here looking for a set of carbs.
    Kevin Duby
  10. Kevin Duby
    Kevin Duby New Member
    Michigan
    I was wondering if you would happen to have the Carburetors from you xj550 still. i have a broken housing on one of mine and am looking for either a full set or to buy a single carb and swap it out.
  11. ricardo anaya
    2216 dobern Ave
    Them sorry bro the motorcycle came with no carburetor
