Bike just quits
Discussion in 'Hangout Lounge' started by johndo, Nov 3, 2007.
  1. johndo
    johndo New Member
    Melbourne FLorida
    Hoping someone has had ths problem, and knows how to fix it. When I'm riding at speed " 40-60" usually within the 10 min, The bike just quits. Once I can get it back to neutral it starts up and then runs fine the rest of the ride. Scary in traffic
    Central Florida weather today 75 degrees 39% humidity. Perfect
  2. RickCoMatic
    If you don't have a Brand New Fuse Panel in there with New-type Blaade Fuses ... I'd have to say that would be the first place I'd suspect.
    The Original Fuse Panels are way, way over their life expectancy.
    Don't let "The Looks of it" fool you.
    The Original Fuse Panel is toast.
    Replace it.
  3. schmuckaholic
    California
    If the lights and everything stay on, it could be TCI module as well. I got bit by that one.
  4. johndo
    johndo New Member
    Melbourne FLorida
    Thanks, I have a brand new fuse panel but the TCI is original
