Carbs
Discussion in 'XJ Technical Chat' started by Joe34, Aug 16, 2017.
  1. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Hey guys. I have a 86 maxim X and I got the carbs tuned. up bike works amazing now. But small issue. After its hot I can start it stop it, start it. Stop it. But if it sits for about 5 minutes, I need to give just a hair throttle to start.
    The carbs have just been synced and cleaned. So not sure what else.
    Any suggestions on help would be apreciated. Thanks.
    have you tried turning petcock to prime for 5 seconds?
    how many miles ? valve adjustment may be due.
    how is your wet set fuel level?
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Valve adjustment correct?
    Idle mixture set correctly?
    Both these affected the ability of my XJ550 to start under the circumstance you cite, however, I am not really an expert.
  4. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Might get valves checked.
  5. Joe34
    Joe34 Active Member
    Halifax nova scotia
    54,000km valves were good 2 years ago father had checked. About 10.k since them.
  6. OldFleetGuy
    OldFleetGuy Member
    Eastern North Carolina
    I had the same problem with my 650 maxim. A real quick fueling stop, no problem. Hard to start if over 10 minutes. Had to give it a little gas to catch.
    Replacing the 36 year old carburetor throttle shaft seals solved my problem. You'll need to re-sync and adjust the idle mixture after replacing these though. Lots of good info on this site about the process.
    Good luck.
    Joe34 and XJ550H like this.
  7. XJ550H
    what were the numbers from last check?
  8. Joe34
    Joe34 Active Member
    Halifax nova scotia
    As far as I know. They were within spec. Not sure number so I dont know. Lol will get down for spring season though.
  9. Polock
    other than maintenance things
    the engine isn't cold enough for choke or warm enough for no throttle starts, sounds normal to me.
    try running a weed-wacker for a minute or two then restarting it
    Timbox and Joe34 like this.
