Short kickstand spring
Discussion in 'XJ Modifications' started by shovel268, Aug 16, 2017.
  1. shovel268
    shovel268 Member
    Edmonton Alberta Canada
    i lowered my bike, cut and rewleded the kickstand .I have a sportster kickstand spring, from a bike I used to have .I put it in a vice and used a pry bar to stretch it,I'm close to getting it on ,but run out of strength .where else's can I find a short spring ?
  2. k-moe
    Shove pennies between the coils to stretch the spring.
  3. shovel268
    shovel268 Member
    Been doing that
  4. mlew
    Local hardware store has a spring assortment to pick from.
  5. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Probably not the best solution but I went into the coffee can full of brake springs at work and found one that would work as I had the same issue when I shortened my kickstand. Been on there since may and haven't had any issues
  6. XJ550H
    [​IMG]buy a spring tool or longer spring
  7. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Our local ACE hardware has an assortment of springs. Perhaps they would have something?
  8. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    where did you shorten the stand? Why won't the OEM spring fit?
  9. XJ550H
    because he is using a sportster spring. I guess it is what he has on hand
  10. shovel268
    shovel268 Member
    It shortened the stand in the middle bike would tip over easy otherwise the Orem spring became to long and would just fall off
  11. shovel268
    shovel268 Member
    Don't have Ace in Canada but we do have lowes, my current fav. And home depot
  12. shovel268
    shovel268 Member
    Only the Incredible Hulk could stretch this spring by hand
  13. shovel268
    shovel268 Member
    Hey I like your idea if it works why not
  14. shovel268
    shovel268 Member
    Going to take it the spring to work tomorrow and reaf on it
  15. Chitwood
    If you go too far with it, it will loose it's tension. I can understand wanting to use a part you already have, but sounds to me like you'd be better off finding a different spring that will work better for your needs
  16. k-moe
    I'd just move the spring loop that's on the stand. Cut, weld, done. Just don't move it too much.
  17. shovel268
    shovel268 Member
    Is the little pin underneath ,the bike, that holds one one of the spring supposed to fall out? And do you hook yer spring on the kickstand and underneath in the same direction or will it fall off?
  18. XJ550H
    pin.JPG this pin should be welded
  19. shovel268
    shovel268 Member
  20. shovel268
    shovel268 Member
    I Harley springs are heavy duty, I got it to stretch to size but haven't tried it yet
