85 xj700x ignition coil
Discussion in 'XJ Technical Chat' started by MaxRodax, Sep 1, 2017.
  1. MaxRodax
    MaxRodax New Member
    Rochester hills, Michigan
    While removing my old spark plugs. My #2 cable came apart at the boot. Looks like really worn part, you can't see the hv wires. I intend to buy the connectors and new boots while keeping the coils. It seems to me is a single piece and the spark wires are not replaceable. Have someone tried that?
    they make a splice you cut the wires and put new wires on the stubs.
    the wire came apart or the plug cap fell off? it screws back on cut the wire back a little
    you can buy replacement plug caps from our supporting vender I think he sells the splice too
    MaxRodax likes this.
  3. Jetfixer
    Or replace coil with Honda CB 750 coils you can still buy them new from Cycle Recycle Part2 they are about 40 ea and have replacable plug wires they also sell wires and the caps. These coils mount in same location as stock . I have ran these for 2 years with no issues.
  4. MaxRodax
    MaxRodax New Member
    I could buy cables and splice it; it broke at the base of the boot. I will try to get the connectors and re-terminate it. If I don't feel satisfied; I will buy a coil like jetfixer suggested. Thanks!
  5. xHondaHack
    Orange CT
    Max,
    Save the spark plug caps because the ones for a Maxim X are hard to find. They have resistors in them as well, and usually need replacing.
    You could also modify them to eliminate the resistors and then just use resistor plugs (the original plugs were non-resistor).
    I think I might even have a spare set of coils and wires that have been converted. I'll send you a picture if you're interested.
    Tony
  6. MaxRodax
    MaxRodax New Member
    Sounds good, thanks
  7. Toomanybikes
    Tsawwassen bc
    The wire twists into cap maybe try screwing it back in.
    k-moe and MaxRodax like this.
  8. MaxRodax
    MaxRodax New Member
    I cut them and retwisted! Life is good. Thanks all!
    k-moe and Stumplifter like this.
  9. Toomanybikes
    Tsawwassen bc
    Glad we could help
