Xj750d convert to carb
Discussion in 'XJ Technical Chat' started by Steveb, Sep 8, 2017.
Tags:
  1. Steveb
    Steveb Member
    Ireland
    Bought a 82 xj750d during week very clean previous owner disclosed that carbs were put in by owner before him. But does not know what bike cane from
    So took it out on highway nice pick up to about 150 kph or 93 mph than sort of hesitates to climb higher due to age and no history did not push harder . Not mechanical minded so are carbs causing it to bottom out at 95 mph?????
  2. Toomanybikes
    Tsawwassen bc
    Carbs are what model? Hitachi, Mikuni
    Jetting may be the issue. Or valves haven't been adjusted causing weak cylinder pressure.
    Stumplifter likes this.
  3. Steveb
    Steveb Member
    Ireland
    Mikuni is what can see on the side of the carbs. When had look today after spin
  4. k-moe
    Regardless of what carbs are on it, I'd start by making sure that the carbs are in serviceable condition by doing a full tear down and refurb. Figuring out jetting is really difficult if the carbs are in need of service.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Just directed him to xj4ever catalog on his other thread. Also asked if they were Hitachi. Damn duplicate threads! If only a moderator were watching...
  6. Steveb
    Steveb Member
    Ireland
    Will get onto it soon as cant spanner myself will bring to my mechanic to refurb the carbs
  7. Steveb
    Steveb Member
    Ireland
    There mikuni carbs Matt I think now po said they were jettef to fit the aftermarket system on bike so hoped all was well and they are up to about the 90mph mark
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    noooooooo!
    Steve
    YOU CAN Spanner with the best of us (unless there is some physical defect that is preventing you - and if so I am terribly sorry about that...) Read this over and know that if I can do it, you sure can to!
    http://xjbikes.com/forums/threads/in-the-church-of-clean.14692/
  9. Steveb
    Steveb Member
    Ireland
    Thanks for vote of confidence if could spanner would save me a fortune always wanted to work on my own bikes but never seemed to get it
  10. Polock
    how's the brakes ?
  11. Steveb
    Steveb Member
    Ireland
    Brakes seem good there better than I expected for the age of bike. Be great if was just a sticking break cheap fix
  12. MattiThundrrr
    Rear brake shoes are known to delaminate on old xjs, causing a complete lock up. Pretty deadly at any speed. Hose life expectancies are 4-5 years. Date of manufacturing is stamped on hose. You do not want to mess about with your life on the line. Either inspect these parts, or have the mechanic check them out.
  13. Steveb
    Steveb Member
    Ireland
    Do you know Matt if there are aftermarket hoses available for my model xj?
  14. MattiThundrrr
    Check the link in the top right corner. XJ4ever is the spot for EVERYTHING! Catalog is so comprehensive that it can be used as a parts reference. Or start a conversation with member Chacal, he's the guy running the show over there. You will get what you need. When I first joined here, there were so many positive reviews for him/xjforever that I thought the whole forum might be a front for the shop, but no, they're just that good.
  15. Steveb
    Steveb Member
    Ireland
    Lol that great matt thanks very much for the info can do with it. I going go browse there now
    L
  16. Toomanybikes
    Tsawwassen bc
    Len has them in stock just got a set for an X model
    Steveb likes this.
  17. Steveb
    Steveb Member
    Ireland
    Is that the xj four ever site I had a browse there it could do with a pair. Looking on eBay the prices are really saucy for lines over a 100 gbp
  18. MattiThundrrr
    Len=Chacal=xj4ever
    Len+you=happy xj
    happy xj=happy rider
    Do the math. You'll get the answer.
    Stumplifter and Steveb like this.
  19. k-moe
    Same = same.
    Start a converstion with Chacal for current availability and prices.
    Steveb likes this.
  20. Steveb
    Steveb Member
    Ireland
    What kind tank range do xj750 have people ???
  21. TheCrazyGnat
    Central PA
    I have an 82 Maxim 750 and I usually refill at 120 miles. That is just me being conservative though. I haven't even hit the reserve tank by that point. I'm not sure what size the 750D tank is, but I think it might be smaller than mine.
  22. k-moe
    That will vary a lot. Speed limits have a huge impact on fuel mileage. Out here in the land of "what speed limit? I thought that was just a suggestion." I can get anywhere between 35 and 50 MPG (U.S. gallons). I live on the Great Plains, so wind plays a huge role as well.
    When the U.S. speed limit was 55 MPH, the XJ750 was getting around 45 MPG in magazine tests.
    Steveb and TheCrazyGnat like this.
  23. TheCrazyGnat
    Central PA
    This has pretty much been my experience. 45mpg is average, but I can get north of 50 just highway cruising.
    Steveb likes this.
  24. k-moe
    I suspect that the original fuel-injection system on the D model would boost fuel milage by at least 5%.
    Steveb likes this.
  25. TheCrazyGnat
    Central PA
    Kind of makes you wonder why someone would take the thing that made the 750D unique and slap carbs on it...
  26. k-moe
    That thing probably stopped working, and since it's a pretty low-numbers machine, and none of the parts were ever officially exported......
    What's a fella gonna do? Fit carbs, or scrap the bike?
    Steveb likes this.
  27. k-moe
    TheCrazyGnat likes this.
  28. TheCrazyGnat
    Central PA
    Yeah, it's easy for me to say I would put forth the extra effort but....
  29. MattiThundrrr
    A crazy, difficult, awesome thing!
  30. Steveb
    Steveb Member
    Ireland
    The guy I got it off said the FI went and did not want to scrap bike so got some carbs tbf to clean to scrap and to rare to part out. I would imagine
  31. Steveb
    Steveb Member
    Ireland
    That it you gotta keep on the road some how I would of done exactly the same to clean to scrap
  32. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Steve....
    Do not ever take your bike to a shop or mechanic. They will just take your money.
    With the advice from this forum...you will learn to be the best mechanic for your own bike.
    A lot of guys on this forum....walk the walk and talk the talk. Heed their advice
    Steveb likes this.
  33. fiveofakind
    San Diego, CA
    Time and patience are needed with these bikes.....tasks may not always go as planned or as fast as you would like
    But once dialed in....these bikes will surely put a smile on your face as well as pulling your arms out of their sockets when flying down the road.
    Steveb likes this.
  34. Steveb
    Steveb Member
    Ireland
    Nice bike already well happy with it only one over on these roads. That what I like the most about it.
  35. chacal
    Probably one of the few left in the entire world's roads!
    Which may give you 2nd thoughts about how much road use that you want to give to it.......[/b]
  36. Steveb
    Steveb Member
    Ireland
    Are they that rare I thought there be few thousand over in Japan holy crap I bought it as a all year bike. I only drive bikes so my plan is all weathers
  37. Steveb
    Steveb Member
    Ireland
    19l tank on the D says get 130 + miles to reserve
  38. TheCrazyGnat
    Central PA
    They must be pretty close in size then.
    Steveb likes this.
  39. k-moe
    The key words are "in Japan." Rare is always relative, and even in Japan there aren't too many.
    Steveb likes this.
