NO SPARK XJ650 MAXIM
Discussion in 'XJ Technical Chat' started by Mike griffith, Sep 24, 2017.
  1. Mike griffith
    Mike griffith New Member
    Middletown Ohio
    XJ650 Maxim cannot get any spark have tried jumping it off the starter got no neutral light a red oil light comes on I've changed and check the oil if it helps this bike has sat for many years but has just been overhauled
    red light coming on is a test of the bulb. start by doing a battery voltage drop test if battery goes below 10 volts when starter is thumbed bike will not start.
    charge battery or get a new one.
    next ohm out entire ignition system. ignition coils, plug caps, pickup coils. trim back spark plug wires 1/4 inch when caps are off.
    if neutral light does not come find out why. you have a clutch safety switch and neutral light is a safety switch both need to work or be bypassed
    all electrical specs will be found in this thread
  3. XJ550H
    check fuses clean kill switch and starter button see if neutral bulb works then test neutral switch.
    does bike turn over with starter button? also pull in clutch when trying this wil overide neutral switch unless clutch safety switch is bad
  4. k-moe
    Describe "overhauled"
    What was done, and who did the work?
  5. Mike griffith
    Middletown Ohio
  6. Mike griffith
    Middletown Ohio
    New top-end valve job
  7. Mike griffith
    Middletown Ohio
    And carbs have been jaded pod filters exhaust
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    That won't work, most pod filters I have seen go on the intake...
  9. Mike griffith
    Middletown Ohio
    My pods are on the intake side of my carburetor they are air filters AKA pod air filters
  10. Mike griffith
    Middletown Ohio
    You might have read what I wrote wrong it meant to say my carburetors have been jet it out pod air filters installed on the carburetors in exhaust was done AKA stock exhaust completely gutted
    Stumplifter likes this.
  11. Stumplifter
    near Irma, WI
    sorry - I must have misunderstood your sentence structure in the previous post.... it seemed to infer that the pods were exhaust. :confused:o_O
  12. Mike griffith
    Middletown Ohio
    and the exhaust was done I use talk text alot so kind of texts what it wants to
  13. Mike griffith
    Middletown Ohio
    I'm really bad at that I need to start reading before I hit send
  14. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Otto correct dozen all ways work EE there.
    Stumplifter and XJ550H like this.
  15. Jetfixer
    If you have a weak battery , this can cause no spark .( even a new battery can have a bad cell)
