Old intake rubbers!!
Discussion in 'XJ Technical Chat' started by charles Byrd, Oct 13, 2017.
  1. charles Byrd
    charles Byrd New Member
    Usa
    What do you guys do with your old cracked rubber intakes ... has anyone modded to accept a silicon coupler?
    Toomanybikes likes this.
  2. Toomanybikes
    Tsawwassen bc
    By new ones or coat them in rtv or use electric waterproof stretch tape or any number of treatments that have been posted here.
  3. XJ550H
    if you buy new ones turn the old ones into a carb rack mount to wet set the carbs
  4. charles Byrd
    Usa
    What im doing with my old ones is welding a turned down 1 5/8 alumium tube to the aluminium flange to accept a 1 3/8 silicon coupler ... anyone wanna send me thurs ill pay shipping possible even buy yur old ones.
  5. XJ550H
    would you post a photo when your done?
    am i correct in assuming that by turned down you mean you turned them down (dia. and length) on a lathe?
  6. charles Byrd
    Usa
    http://i268.photobucket.com/albums/jj3/scrapkilla321/20171013_113106_zpsnj7r2ail.jpg
    Yes you bet ... the aluminum pieces inside the rubber is about 1/2 flange roughly (i just eye balled it lol ) it has a 1 5/8 od dia . The carbs are about 1 3/8 od dia so i picked up 2 different couplers one for a 1 5/8 to 2 inch to adapte cbr 1000 itbs for efi and 1 3/8 couplers for stock carbs ... im going to make another set later for efi if these work out. The turning down part is for i can get a 1 3/8 coupler to fit on a 1 5/8 tube the tube is fairly thick and the inside is a good size to flow ...
  7. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Photo bucket image not working for me, since you probably aren't a paying their new fees? Can you upload the image to the posting?
  8. charles Byrd
    Usa
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I found pictures of what looks like SR20DET. Red top too! Yummy. Wasn't a whole lot of xj intake though... Wanna see finished product, both intake boots and Sylvia!
  10. charles Byrd
    Usa
    That's actually just the stock Ka in my Nissan I done sold all that though you can see old pictures of when I try to put an xj750 on a Sprint Kart but I just started the intake today I have yet to weld this but this is pretty much a finished product minus the weld my works welder there was taking a shit today. I also was only able to complete one because of the time frame I had took me about 30 to 40 minutes to produce this pretty straightforward from there you get a silicone coupler of an inch and 3/8 and you couple the carburetor to it I'm also going to be making some for EFI if I eventually I just want to ride my bike already
    https://ibb.co/giWK0b
  11. charles Byrd
    Usa
    So what do you guys think ... anyone want to donate there old rubbers ... ill pay for shipping to cali
  12. Timbox
