Stupid questions (I think)
Discussion in 'XJ Technical Chat' started by shirali, Oct 18, 2017.
  1. shirali
    shirali Member
    Sweden
    Was wondering if it's possible to replace front wheel with a smaller 17 inch wheel? And if so, from which bike?
    Easiest stuff do you for reducing the weight of my bike? It's a seca xj750 1982.
    I want a smaller tank that is direct fit but don't know which one fits.
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Not sure about the front wheel but there is an entire thread about which fuel tanks interchange
  3. XJ550H
    you can make any tank fit if you can do fab work
    why do you want to lighten bike? or want smaller tire/rim up fromt.
    there is an older thread where poster did the front tire/rim look at newer yamahas
    seca 550 tank ( euro xj550)is a close to fit tank for your bike
    Fuel tank interchange information
  4. shirali
    shirali Member
    Sweden
    I want to make the bike easier to handle and a bit lighter too. Just to test out stuff.
  5. XJ550H
    it took me about a week to get used to the weight difference of my 750 maxim and 550 maxim now I do not notice it at all
  6. shirali
    shirali Member
    Sweden
    But it should be possible to find a smaller wheel and make the overall weight lighter?
  7. XJ550H
    yes you can find a smaller wheel for the front
  8. shirali
    shirali Member
    Sweden
    Which ones will fit?
  9. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Easiest conversion is slip radian or FZ600 forks, wheel, brakes and fender into your existing triple clamps.
    This gives you a 2.50 x 16” front. Then use the 3.0 x 16” rear from a Maxim to balance it out. This will lower the bike about 1” in front and 3/4” in rear. I don’t recommend a 17” in front. Most are 3.5 and call for a radial. A radial rear can be used with a bias front but never mix a radial front with bias ply rear. A bike with a wider rim in front than the rear would look goofy and handling might be dangerous. The 16” combo I proposed allows same tire sizing as the Radian.
    XJ550H likes this.
  10. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    changing the front wheel size will also alter the speedo callibration
  11. Simmy
    that is true. One day I need to compare mine to a gps and see how far out I am. I can’t recall which worm drive I used and if there is even a difference amongst them.
  12. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Our town has a radar unit on the edge of town that tells you how fast you are driving. My speedo is spot on to 35 mph. Since the speed limit in that area is 25, I don't dare press my luck at higher speeds.
    A gps app is a great idea as well.
  13. shirali
    shirali Member
    Sweden
    the speed calibration isnt something that bothers me but i want something thats more cost efficient instead of changing forks and stuff etc.
  14. XJ550H
    get the speedo that goes with the wheel. where he wants to reduce weight dump the cluster and get one of those small all in one units
  15. Polock
    you could take off one caliper and it's rotor and pretend it's a 650. then loose the anti-dive stuff
  16. shirali
    shirali Member
    Sweden
    That sounds very dangerous from safety point of view.
  17. Polock
    well 650's have one brake and they seem to stop fine, change to a 650 master cylinder and it will almost be a proven setup.
    changing wheel sizes never won any safety awards
    one brake setups have half the failure points
  18. k-moe
    So is changing the front wheel diameter.
    You'll be altering the front-end geometry, and therefor altering the handling. The steering will speed-up a bit, and become less stable. Both the Seca and Maxim 750 are somewhat prone to headshake under some conditions as-is.
    If you want it to be lighter, start with the font fender. After that, I'd look into a 4-1 exhaust, removing the passenger foot-pegs and hangers (you'd need to fabricate a muffler mount), Swapping the ATARI for a smaller all-in-one gauge, and then.....well there isn't much left that would be of advantage without ruining the machine.
    If the bike is to large for you, I suggest buying something newer, and lighter. 80's bikes are, by their very nature, heavy. There is no changing that.
    shirali likes this.
  19. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I'd like to add a note: you can't just ditch the fender... underneath is a fork brace. Keep that part on, or you're gonna get flexy forks!
  20. k-moe
    Yes. I was not very clear. I meant to imply that a plasic fender is lighter. Running without a fender is a fool's game.
  21. shirali
    shirali Member
    Sweden
    if i can get a rear maxim wheel which is 16inch and then a another 16 inch/17inch wheel from another model, would that be alright?
  22. shirali
    shirali Member
    Sweden
    But the question is which 16/17 inch wheel is a direct fit? Without having to change other components?
  23. Simmy
    Radian or FZ but you also need the fender. And a way to mount it that’s why you need the forks.
