1982 Yamaha XJ 650 Maxim gas issues
Discussion in 'XJ Technical Chat' started by Dakota Wallace, Nov 14, 2017.
Tags:
  1. Dakota Wallace
    Dakota Wallace New Member
    Concord nc
    okay so I recently just rebuilt the carburetor to my bike. I’d have to check what jet was placed where in my carb I’m pretty sure the bigger one was closer t the float. The only thing that I did not put new in it was the drain plug on the bowl and the float it’s self. But I’m able to actually blow into the fuel line and I mean it goes in. I also have my vacuum line hooked up. I used an electrolysis to clean my gas tank so I know that’s all good. The valve it’s self I cleaned as well. Please help I’m stumped on this. When I rewired my bike I used a simple wiring method if that makes a difference
    unless your carb bowls are full air will flow into fuel line
    Main FUEL Jet Size: #110
    Pilot FUEL Jet Size: #40
    main jet goes in center of carb on emulsion tube with slide needle above it.
    floats installed upside down?
    what exactly is your fuel problem ?
    no fuel to the bowls?
    did you wet set the floats?
    Setting the fuel levels
    do you have a picture of your wiring diagram?
  3. Dakota Wallace
    Concord nc
    Well I guess getting fuel is no longer a problem, I left it on prime all night to let it flow in. Problem now is that when it starts it revs and idles EXTREMELY high. I have to shut it off real fast as I don’t want to blow the engine.
    I’m dead certain I placed the jets in the right order when I rebuilt it as I took one off cleaned the area and put the matching item where it was. I’ve tried to screw the adjustment screws all the way in. I’ve tried the general 1- 2 turns back out. and I’ve tried them 5 turns out like the original were. And even farther out than the 5. I’m so stumped.
  4. Dakota Wallace
    Concord nc
    The wiring diagram I used was the basic one in the green picture
  5. Dakota Wallace
    Concord nc
    Have not got it to start since last stated
  6. Dakota Wallace
    Concord nc
    What way does the float go. I have them with the higher part facing down. Toward the needle
  7. Rooster53
    North, FL
    Up vs down can be confusing - refer to the link that XJ550H provided in post 2 and page 7 shows the correct orientation.
    The mixture screws are going to have very little affect on idle speed. More likely is either the idle speed screw located between carb 2 and 3 is too far in, or the throttle cable is not installed correctly holding the butterflies open. Some members have even accidentally swapped the choke and throttle cable by mistake.
    Verify the idle speed screw is in contact with the stop linkage and then back off the idle speed screw knurled knob to where it just touches the stop linkage, then maybe CW a half turn.Verify with the throttle released there is slack in the throttle noted by both the feel at the grip and the slack in the cable at the carb mounting point.
    To this standard?
    http://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    Which also covers the initial bench sync to get things close.
  8. Dakota Wallace
    Concord nc
    I was able to get the bike to stop idling so high. Sometimes I am able to start her without starting fluid. I don’t see a problem with the throttle cable or adjuster, sometimes it seems like she wants to start easier when connected to a battery charger, but everything gets the power it’s supposed to without t also. I appreciate y’all patience with me
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Starting with a battery charger or jumper cables connected could be a sign of weak battery causing low voltage while cranking. You may have just enough voltage to get some spark, but below about 10 volts the TCI won't fire. When my bike cranks but doesn't start, then starts when battery charger is connected, it is a sign of a weak battery as the charger is keeping the voltage up enough for the ignition to spark properly.
  10. Dakota Wallace
    Concord nc
    Could this actually keep it from running after it has started though? I can get it to run for a good 5 seconds before dying out. Also, the gas tank is NOT full. No where near. Honestly just enough so that I could get it to start (16 oz approx) could this be keeping it from staying running?
  11. k-moe
    You need at least 1 gallon in the tank. There is a volume of fuel at the bottom of the tank that the petcock will not drain.
    XJ550H likes this.
  12. Dakota Wallace
    Concord nc
    Okay so I took your advice and added a little over a gallon to the tank, still no avail. Sometimes I have to use the starter fluid still but not that much. The bike still runs for only 3-5 seconds before dying out. I noticed that while it is running giving the bike throttle does nothing to RPM. Now I don’t have a tachometer on it but I can tell when I do I’ve it throttle it makes no difference. I am dead positive the cable is the right one I’m using (thickest cable for clutch, middle thickness for throttle cable, and the smallest cable for the choke. If this changes or gives you an idea on the problem. Also if by chance can you show me how far down the needles for the choke sit down. I noticed mine do not sit all the way down and have a slight gap and play in the whole linkage before they move up when activating choke.
  13. Dakota Wallace
    Concord nc
    Also I should have mentioned, when I rebuilt the carb the needles under my floats weren’t exactly the same. The size and all is good and they have the spring on the back. The only thing they did not have was the wire piece on the back that hooks to the float. Oh and the adjustment screws for the idle had a clear tubing on them but my original ones did not so I took those off thinking they were just to protect the needle tips. If any of this could be a problem let me know. I am providing a picture to the carb kit I bought
  14. hogfiddles
    Can you confirm that you see the BUTTERFLY SHAFTS rotating when you twist the throttle? Easy to do.....watch the end of the carb rack and see if you see the c-clip rotate when you twist. If it does, the cable is hooked to the right place.
    If it doesn't, then pull the enricher lever....does it move now?........cables hooked up backward.
    Is your vacuum line hooked up to the manifold Port AND your petcock?
    What happens if you set the petcock to PRI for two minutes before trying to start?
  15. Dakota Wallace
    Concord nc
    All of those things are correct and setting it to primefor two minutes and starting still causes bike to die off after 5 seconds
  16. hogfiddles
    Put the bike on the center stand
    Put a different line on the petcock and see if gas pours through into a container
    .on PRI
    .on ON, when you're cranking the engine (or carefully sucking through a surrogate vacuum
    line)
    Put the regular fuel line back on, pull it off at the fuel T......got a good stream of fuel€
    Put some drain hoses on the bowls, run them into a clear container
    open the drain screws
    Do you get 4 good streams of gas pouring through?
  17. Dakota Wallace
    Concord nc
    All of that is good as well
  18. hogfiddles
    1. Check the airbox to make sure there's no mouse nest blocking the air
    2. Open the filler cap in case the vent is plugged and creating a tank vacuum
  19. hogfiddles
    I am simply trying to either find or rule out a fuel issue at this point. Once we can determine that fuel supply IS or IS NOT the issue, then we can look elsewhere, but I don't want to go shooting in the dark at a million things at once. If you do it that way, then sometimes problem will stop, and you'll have no clue which of the attempts solved it.
    So, we're isolating fuel issues first. Then we'll issue something else......etc......
  20. Dakota Wallace
    Concord nc
    Still no luck
  21. hogfiddles
    Ok--- so you have verified that there is plenty of fuel going TO The carbs.... now we have to find out if fuelnis going THROUGH the carbs. Get a can of starter fluid. Pull the plugs out and give each cyl a snort-- put the plugs back in and connect the plug leads. Try starting and see if it fires at all....
  22. Dakota Wallace
    Concord nc
    I just checked the rectifier and all is well there also
  23. Dakota Wallace
    Concord nc
    What do you mean by “pull the plugs” what plugs? I’m able to spray starter fluid into the air ways and get it to run for a few seconds that way and continue running if I continue spraying
  24. Dakota Wallace
    Concord nc
    Okay man I’m sorry for wasting your time but, it turns out I tied the kick stands kill switch together since I didn’t wire that in and I’m tying them let’s it run. The first two runs it ran pretty smooth and it starts up every time now, just idles very high. I already checked the throttle knob but any info on getting it to idle right I’d appreciate.
  25. Alan Marshall
    Alan Marshall New Member
    USA
    XJ550H; Thanks so much for the info on adjusting the floats. I'm guessing that's my problem now. "82 XJ650 that hadn't been run since "89. I bent two of the tangs getting the carbs apart, so just adjusted them by measuring the two that didn't get bent during disassembly. It starts right up but is very cold blooded, runs great in 1st and 2nd, but dies when I hit 3rd..... until the revs hit about 4000. Then it screams! As soon as it cools I'll put the plugs and look at them. What I get for rushing the job. I live in the snow belt and any day now may be the end of riding until spring. Again, thanks for the post.
