  1. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    I hear that. This time of the year is crazy.
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Left it covered in the garage today. -6 feg F plus wind chill even lower.
    Hope all had a good Christmas and a great New Year.
  3. Jetfixer
    Went to ER I have type A infulenza...it is extremely cold out and all I did was stare at my bike fantising about riding on a nice 70 degree day:D
  4. cgutz
    SE South Dakota
    Hope you get better soon.
    wgul, Jetfixer and Stumplifter like this.
  5. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    Been a few days since I have posted anything.
    Going to change the left control switch for the turn signals and the horn. I haven't had a working horn since I bought the bike, not the horns themselves but the inner part of the switch has been broken. Day off and I need to do something till it warms up and then off to the races.
    Last week was able to ride in the afternoons and surprising I only saw one other bike out and about. Might be because it was hovering around 32 degrees as the high. Very Cold for this location oddly no rain just cold. Rain in the forecast for the next couple of days then back to cold.
    Noticed that both my front forks are leaking oil. Not sure why I just had them done two years ago.
    What I did notice is that one day when it was like 25 degrees out, I went out riding and during the ride, I noticed the oil residue on the forks themselves.
    Another project once it starts to rain regularly
    Last few days I have been able to ride around town, and by this, I mean around Medford Oregon. Usually takes about an hour to take the scenic route to circumvent the city. Looks beautiful from afar and even better once I get some elevation.
    May the New Year bring many more happy riding miles to everyone.
    Wintersdark and wgul like this.
  6. dowski68
    Medford, Oregon
    Well changed out the control witch for the horn and turn signals and that didn't work. Got power to the horns but nothing happens when I push the button.
    power on = power to horn
    push horn button = no interuption of the power to the horn
    Any ideas
  7. dkavanagh
    Rochester, NY
    It's too damn cold! If it were a little warmer, I'd be willing to go sit on it and wish I was riding. Too cold even for that!
  8. dowski68
    Medford, Oregon
    Oh crap your in NY and ya'll like you were stck into a blast cooler.\
    I would stay inside as well
  9. Jetfixer
    It is minus 2 F out. I have the flu my spare starter motor showed up and have not tested it . My garage is not heated nor fully insulated sooo I sit and read the forum at least that helps me feel connected till spring.:)
  10. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    It feels wrong to almost click the like button for Jetfixer's post, but sadly that is about the situation here as well
    Wintersdark, Stumplifter and Jetfixer like this.
  11. wgul
    wgul Active Member
    Boston
    Feel better soon. I like the part about at least being able to read here and get you through until Spring.
    Jetfixer likes this.
  12. wgul
    wgul Active Member
    Boston
    Found a good price on a new (to me) speed/tach for xj650 #2. The current gauge is really faded and has a busted housing. May have to push the baby into the kitchen from the unheated garage to make the switch. Wishful thinking only
    Wintersdark and Jetfixer like this.
  13. Wintersdark
    Switch is after the horn. Switch should allow the horn to ground. Its wired a bit wierdly imho, but there should be +12v at the horn all the time. As you've got power there's the fuse is good.
    If you stick a meter on the switch itself, you should have no continuity between the terminals with the button off, and continuity with the button pressed, right? Just to confirm the switch is working. Also, you should have continuity from the switch to ground all the time with one terminal, and only while the button is pressed off the other terminal.
  14. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Finally taking my carbs to church. One more butterfly to get out and then its off to the ultrasonic cleaner. And to then get my parts
    Wintersdark likes this.
  15. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Almost
  16. hogfiddles
    It was only down to -5 here......
  17. Wintersdark
    Rumour has it we'll go from the -30 we've had over the last week to back above freezing on New year's day. The street I live on is all packed snow and gravel, but the main roads are already cleared, hoping I can get out and ride a bit then.
  18. hogfiddles
    30 degrees colder than yesterday's 20° heatwave (ignore the pm.... son set the clock wrong, it's AM-- took the pic about 1/2hr ago.....
    Stumplifter likes this.
  19. Pizzaman
    Pizzaman Member
    north Seattle
    Went out for a nice ride. Got rear ended at a stoplight. Luckily just a tap enough to bend the license plate. Same spot I got rear ended in a car about 10 years back
  20. hogfiddles
    Glad you're not injured.
    Glad the bike is ok.
    I hope you didn't let them get off too easy.
    At least you weren't in an airplane in Costa Rica
  21. Mike griffith
    Mike griffith New Member
    Middletown Ohio
    Anyone know the widest rear wheel you can put on a xj650 maxim
  22. Wintersdark
    The real wheel that's already on it. There's very little clearance between the swingarm and the wheel as it stands, there's no room for a wider wheel. Just look at how small that gap is.
  23. Plug
    Plug Active Member
    Missouri
    Glad you were ok!!! Hate having to come to a stop in traffic.
  24. hogfiddles
    Depends how much money you have
  25. dowski68
    Medford, Oregon
    Damn I feel as though I am riding in the summer as it is only 34 here in southern Oregon with a high of 50.
    I still riding with a baklava which has stopped the wind from going down my neck. So much better.
  26. Wintersdark
    Sorry, I hate to be that guy, but now I'm picturing you riding having crammed baklava around your neck. I imagine the honey may help seal your neckline, but you'll end up with filo pastry and pine nuts everywhere ;)
    dowski68 and Stumplifter like this.
  27. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Didnt work on the bike today. But I built my carb stand. Message_1514933339991.jpg
  28. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Balaclava - baklava ??? So close :p
    I did the same thing last week and my wife let me know I was wrong... :oops:
  29. XJ550H
    what did you use for control
  30. XJ550H
    -20f last night -27f the night before tonight is a heat wave 5F
  31. Wintersdark
    Us too; so weird. Went from -30c to +2c literally overnight. Walk outside, and after weeks of "it's so cold it hurts your face" suddenly it feels like it's summer.
  32. saftie
    New York, NY
    Installed battery tender on my xsr today, a battery nut slipped out and fell into bike. I ended up spending an hour removing stuff.
    New bikes are just so compact.
  33. dowski68
    Medford, Oregon
    Walked outside and looked at my bike then walked further to see that the fog is so thick that you can barely see halfway down the block. Weather guessers say it supposed to rain for the next few days. Covered bike with bike cover sigh of sorrow :(
  34. dowski68
    Medford, Oregon
    As my wife put it I am not made of SUGAR I sucked it put on my snival gear AKA inclement weather gear I went riding. Logged in another 40+ miles and low and behold the sun came out! :)
    Wife gets off at 2pm and stated that she also would like to go for I ride.
    Being who I am I had to ask me or the bike ?
    Her reply is maybe both but the bike first YEAH!
    Never pass an opportunity like that up.
    :D
    Chitwood likes this.
  35. Plug
    Plug Active Member
    Missouri
    Logged a 15 mile ride.....at 15F.....just so I could say I did.....man it did not want to start, and took forever to warm up.
    dowski68 and Wintersdark like this.
  36. dowski68
    Medford, Oregon
    Although it is hovering around 38 degrees my x takes a little bit to warm up also. Gives me time to put on my snival gear for the ride.
    Logged another 40 miles with the wife. Took her to a ma and pa hamburger joint that she loves to eat at. Get back and all the grandkids are here, guess that puts the kabash on riding the wife LMAO :rolleyes:
    Ah the joys of grandparent hood.
    Rain tomorrow then sunny for two days followed by a weeks of rain.
    May be a good time to actually change the pods back over to the original airbox. Oh wait winter term begins Monday the 8th of January.
  37. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    Got to ride to work the last couple days wearing my new bright yellow reflective motor cycle jacket. I was afraid that people would laugh at me when I got hit wearing all black gear on my all black bike after dark. Now people will just laugh at the irony when I get hit wearing my bright yellow reflective motorcycle jacket.
    It's been 4 Celsius and fairly dry here so my short 5k ride to work is mostly pleasant.
    My odometer just turned over 40k yesterday. I'm not too excited though because it is a replacement and the mileage is really closer to 20k.
  38. Wintersdark
    So jealous! We're having a Chinook, with temps up around 10c (a far cry from -35 last week) but the side roads are still covered in lot of snow. If it stays warm, may take the XJ out for a really cautious ride on Sat though.
  39. dowski68
    Medford, Oregon
    I too have a bike like yours although mine is the X model of 1986 and I to wear all black-only due to a motorcycle outlet store was going out of business and everything was 1/2 half and it was in the midst of winter. Didn't think about the 90+ degrees for at least three months of summer :rolleyes:
    Redardless of what we are wearing people still don't see motorcyclists. Something to do with how our brain stores images in little blocks of information rather than a continious or constant viewing of images. I happened to catch a documentary on how the brain stores images and it really made sense to me.
    I think that the best gear or lack of proper gear to be seen is a youtuber who wears a chicken suit while riding. Definitely gets noticed and that is what is important!
    RIDE SAFE MY FRIENDS
  40. dowski68
    Medford, Oregon
    Overcast and raining today-covered yamaha with her rain coat lol maybe tomorrow I get to ride a bit more.
  41. Jetfixer
    Temps were 57 degrees but it was raining and humid , pulled in garage and thought I'd try to start bike....No joy kept backfiring , Wife comes out "Why are you trying to start it you can't ride " My answer because I want to hear it run , I had winterized it so probably should not have tried . Today temp is 22 degrees :( and Saturday 8 degrees , I guess it is time to pull carbs and clean fuel enrichment circuit , but this will wait till temps go up 60 days and counting till spring .
  42. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Tore brake calipers apart while I wait for my carb parts.
    Id say they never been rebuilt before.. .....
    Wowwws
  43. Ribo
    Ribo Prefectionist
    New headlight and tank paint.
    kosel, Craig B and Plug like this.
  44. Craig B
    Craig B Active Member
    Ontario, Canada
  45. Chitwood
    Installed some cb750 bars that I modified on the 82, and installed a passenger backrest on the 81
  46. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Ordered my colortune plug today.
    Can't wait to get the carbs back from church.
    Wintersdark and Tim O like this.
  47. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Black over black logo and stripe looks awesome. I like!
    Ribo likes this.
  48. Ribo
    Ribo Prefectionist
  49. Craig B
    Ontario, Canada
  50. Chitwood
    I agree. I will be switching to those gauges at some point in the future when I do some other mods. The tach in your link is cable driven? Mine is electronic, I'll have to find one of those. Does the ratio they list on link of the one you used matter for an electronic one?
