' 81XJ750 - Clutch not engaging for tire to spin freely
Discussion in 'XJ Technical Chat' started by T-MoneyAllDay, Jan 12, 2018.
  1. T-MoneyAllDay
    T-MoneyAllDay New Member
    LA
    Guys, I'm at the end of my rope changing my clutch. I've followed several articles here and videos on youtube, but I just can't seem to get my clutch to work properly.
    What I know:
    I can see the plates move when I pull the clutch. - see video
    I can't move the lever by hand. Only with the clutch handle.
    I tightened the 5 screws/springs as close to some pictures I found. I read it's supposed to be 7.2ftlbs which means it shouldn't be super tight.
    I've used my haynes manual and the links found inside the .txt
    I wasn't able to submit my post with the links embedded but I put them in a text file and uploaded them. They have a video of my clutch in action which I think is key to y'all understanding what I did wrong
    I'm just looking for any guidance on what to try next.
  2. T-MoneyAllDay
    LA
  3. XJ550H
    when bike is on center stand bike in gear clutch pulled in rear tire will spin due to the oil in between the clutch plates. this is nornal
    you also need to soak clutch plates in oil overnight before installing them not stright out of the package as shown in your vid link
  4. T-MoneyAllDay
    LA
    Actually, it doesn't spin at all. Say I have it in 1st gear, if I pull in the clutch it still doesn't let the tire spin. The tire never spins freely.
  5. XJ550H
    what you are saying is with clutch pulled in you can not spin the tire by hand?
  6. T-MoneyAllDay
    LA
    Yes, I pull in the clutch, spin the tire and it stops as if its in gear.
  7. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I know this will not fix the problem but the spring on the arm where the cable attached is not in the proper place.
  8. Polock
    if the plates didn't separate like they should when you pull the lever, you couldn't move the wheel with your hand.
    go for a ride and see if it works
  9. k-moe
    It won't spin free like a bicycle wheel; you have to keep moving it.
    Try this:
    Turn the wheel with the clutch engaged (lever out), then with the clutch disengaged (lever to the bar). Is the result same = same, or different?
  10. k-moe
    It won't fix the current problem, but correcting that will prevent a future problem. Good catch.
  11. k-moe
    And that ^^^ makes me wonder if the gear on the throwout arm is in correct contact with the gear sector on the throwout plunger. That would account for the wheel acting like the clutch never disengages.
    Chitwood likes this.
  12. hogfiddles
    Almost looks like the lever on top of the catch is too far forward....
    Edit: I typed that yesterday, but never hit the send button.....DOH. Anyway, I agree with k-moe......try removing the c-clip, pull the arm off and index it back a couple teeth and see what happens.
  13. Toomanybikes
    Tsawwassen bc
    There are aligning marks on case and lever. You may have to remove clip to see its location.
  14. hogfiddles
    So compare your lever to the pics from Toomanybikes.......
    See how 'far forward' yours is? You're not getting the clutch to disengage. Put yours back a couple teeth and see how it feels. You may need to go ack more to get the preload. Then you'll dial it in the rest of the way with the adjustments at the end of the cable, as well as on the left hand lever.
    I'm not seeing anything wrong with the spring, though.....
    Dave
  15. k-moe
    The hooked end that engages the arm is just sitting under the arm, instead of the arm being inside of the hook.
  16. k-moe
  17. Rooster53
    North, FL
    Here is another pic of the lever and cover alignment marks:
  18. hogfiddles
    Strange.… Maybe I don't have the right picture. But on my screens I don't see either ends of the springs at all. Oh well
  19. jayrodoh
    jayrodoh YimYam
    Cleveland
    I know I'm a little late to the party but another indicator to me that arm is in the wrong position is the way the cable is adjusted. Assuming you have the right cable then the level is definitely not clocked correctly on the shaft.
    XJ550H likes this.
  20. T-MoneyAllDay
    LA
    It was slightly different. Clutch pulled in had a little more travel.
  21. T-MoneyAllDay
    LA
    I did end up doing that. I removed the C(?)clamp and adjust it until it had a tight pull. The clutch worked fantastically but no joke the clutch center (according to my haynes) section where there are 5 points for the spring to settle in and teh screws to go in sheared. 2 of them snapped. Looks to be aluminum. I'm going to have to order a new clutch center, but I still don't know why it snapped. I didn't over tighten the screws. You could unscrew with one finger and I was using a ratchet about 8 inches long.
    Thanks for all the help though. I'm thinking it was just original clutch parts and weakened from wear and tear.
  22. T-MoneyAllDay
    LA
    Thanks for the picture. You are right. I had to take off the arm and get the clutch cover on first. Once it was snug. I could put on the arm at the right angle for a correct pull. I managed to get it working once or twice before the clutch center screw holes snapped. :(
  23. T-MoneyAllDay
    LA
    So I finally got it all working, y'all. It it turns out I had the clutch plate bolts too lose so when I'd spin the tire the bolt heads were hitting the clutch case cover. I basically tightened each bolt until it didn't feel loose and then tightened a little more. Now the clutch works perfectly and doesn't slip even in the higher gears. Thank you for all your help!
    Tim O likes this.
  24. lostboy
    A torque wrench is a excellent investment. Good to see you got it fixed.
  25. T-MoneyAllDay
    LA
    Got one you recommend? There's a 5-200lb one at harbor freight but most seem to be in the 50-200 range. The hayne's manual recommends 7lbs.
  26. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    2 torque wrenches, one in foot pounds for the higher numbers, one in inch pounds for the small stuff. Just multiply ft/lbs by 12 to get in/lbs. Therefore, 7 ft/lbs is 84 in/lbs.
    As for brands, you usually get what you pay for. I have my dad's old Snap On, it's older than me, still works like a charm. Which is cheaper, an expensive wrench, or having to repair whatever got screwed up when your cheap wrench failed? Plus after the failure, you have to buy the good wrench anyways!
    XJ550H likes this.
