xj650 Engine Swap
Discussion in 'XJ Technical Chat' started by Rob nan, Jan 30, 2018.
  1. Rob nan
    Rob nan New Member
    St Catharines, Ontario
    Does anyone know if the 1981 xj650 maxim have the same mounting points as a 1980 xj750 seca? Also, are the drive shafts the same? Any advise would be great. Thanks
    what you need to know is found in this thread as well as many other things but in a nut shell yes, if they made an 1980 xj750 seca
    The Information Overload Hour
    check for the number on your motor short vin
    750's:
    1982 XJ750 Maxim USA: 15R
    1982 XJ750 Maxim Canada: 15T
    1983 XJ750 Maxim USA: 22R
    1983 XJ750 Maxim Canada: 22T
    1983 XJ750 Midnight Maxim USA: 33N
    1983 XJ750 Midnight Maxim Canada: 33U
    1984 XJ750 Midnight Maxim Canada: 22T
    1981-83 XJ750 Seca USA: 5G2
    1981-83 XJ750 Seca Canada: 5H2
    1985 XJ750 Maxim X Canada: 1FL
    1986 XJ750 Maxim X Canada: 1MY
  3. Rob nan
    Rob nan New Member
    Thanks for a prompt response. Looks like I have a lot more reading a head of me.
    That great to know I can swap a 650 engine with a 750 engine.
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Motor mounts are different between Seca and Max... Max is rubber mounted, Seca is solid. I'm not sure about differences between 650 and 750, but I know the 750s are interchangeable if you make a few changes to accommodate the difference between the mounts.
  5. Toomanybikes
    Tsawwassen bc
    You can use the 82,83 xj700,750 maxim also has rubber front mounts.
    If you can use the matching carbs so that jetting is not an issue
