XJ650 Headlight Mount Grommet
Discussion in 'XJ Technical Chat' started by Jmkrull, Feb 20, 2018.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    Hey, does anyone know what the part number is or where to find rubber grommets for the headlight? There's a metal plate that goes against one side and the other goes against the headlight bowl. Not finding too much on this... Thanks!
  2. chacal
    I think this is the one you are needing?
    HCP4638 OEM headlight stay bracket-to-headlight housing ("bucket") rubber DAMPER, this large, round, square-holed grommet snaps into the bucket where the mounting bolt passes through. Use 1 on each side for all of the following models: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and XJ900N model. Each:
    http://www.xjbikes.com/forums/threads/xj-parts-catalog-section-d-electrical-system.44641/
  3. Jmkrull
    Jmkrull Member
    Minneapolis
    It's Yamaha 341-84336-00-00 Grommet; New # 90480-16114-00 (YAM-341-84336-00-00)
    Thank you though!!
  4. k-moe
    Same part. Chacal has his own set of part numbers.
    Plug likes this.
  5. XJ550H
