Taper bearing how to.
Discussion in 'XJ DIY How-To Instructions' started by razz1969, May 20, 2015.
  1. razz1969
    razz1969 Active Member
    Cleveland, Tx
  2. k-moe
    A brass drift and hammer can substitute for the pin spanner.
  3. shovel268
    shovel268 Member
    Edmonton Alberta Canada
    do i need the washer with the locking tabs?
  4. razz1969
    Cleveland, Tx
    The xj750 does not have it.
  5. shovel268
    shovel268 Member
    mines a 650
  6. razz1969
    Cleveland, Tx
    According to the service manuel, it does not have it either.
  7. shovel268
    shovel268 Member
    are the adjusting nuts to be expossed woth the top tripple tree sitting on top? looks strange to me
  8. k-moe
    The two jam nuts go below the top yoke. The yoke is held in place by a pinch bolt and a larger fixing bolt that screws into the steering stem.
  9. shovel268
    shovel268 Member
    like this won't they rust and how do yiu set the tension
    thank you
  10. jason191918
    jason191918 Member
    Weston, WI
    is this the same procedure for a xj700x?
  11. k-moe
    Yes.
  12. jason191918
    jason191918 Member
    Weston, WI
  13. jason191918
    jason191918 Member
    Weston, WI
    I see some are tapered with races and others are sealed (i assume ball bearings). Is one preferred over the other?
    Edit: maybe the picture just has the tapered dropped in the race...
  14. k-moe
    Some of the photos do show the ball races before they are removed.
    The upside of fitting roller bearings is that they tend to have a longer service life and rarely need to be adjusted.
  15. jason191918
    jason191918 Member
    Weston, WI
    ok thanks. i'll look for the nonsealed roller bearings.
  16. k-moe
    Chacal has the required bearing sets, and he'll get them to your door in a day or two.
    XJAUS likes this.
  17. Tim morris
    Tim morris Active Member
    Hopatcong NJ 07843
    Well okay fellas I just did the tapered seat bearing modification well there was a problem in seating the larger bearing on the Fork stem you can't heat the bearing and get the grease in it because it's hot so I was faced with the Dilemma of putting it on dry and smear and grease all around it well I didn't I greased it by hand I put a palm of grease in my hand and push the bearing forcing the grease up into it I then drop the seal on the stem carefully placed the bearing carefully on the stem then took the old stem bearing race put it on top of the bearing with any size piece of pipe I had laying around and knocked it right into place with a few taps fully greased fully loaded I hope this helps anyone in the future God bless XJ forever but I was kind of wishing they were Timken bearings which I'm sure they could be found knowing the specifications of the new replacement tapered bearing
  18. k-moe
    You grease it after it's cooled. It doesn't take much. You're not greasing a wheel bearing.
    I also put the lower clamp and stem into the freezer the night before to get a little extra clearance.
  19. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Did you drop a few full stops down the frame while you did that?
    Good job though.
  20. Tim morris
    Hopatcong NJ 07843
    Let's just say I love grease inside all bearing s so no water will ever get in thanks
  21. Tim morris
    Hopatcong NJ 07843
    Nope stem was out off of bike
