Mikuni BS float bowl post fix.
Discussion in 'XJ DIY How-To Instructions' started by Christopher McTavish, Mar 19, 2018.
  1. Christopher McTavish
    Christopher McTavish Member
    Tri-cities,Washington
    So my dad and I after looking and taking a few measurements came up with a plan to fix float post.
    First step was to pull out the steel nail the PO put in to help hold broken post (didn’t work lol) then we put the carb in milling machine and mill broken post flat.
    We then found a piece of 1/4” aluminum round stock and cut a part about the right length. Put it in the lathe and drilled and tapped for an 8-32 screw.
    FFBDA535-0A20-4C58-9EC2-D43FF0FCC4E7.jpeg A32BD4DC-475C-4597-8E5E-F73E256343FE.jpeg C5F90593-40CE-4DE4-AB38-5877568F28F2.jpeg 7BD1F270-98F4-495A-839A-BB0CDDE287F5.jpeg
    After that we drilled and tapped remaining post on carb body. Then using blue loctite242. (Researched and found to be most gas resistant.) screwed the two parts together and let sit over night to cure.
    We did a dry fit first to make sure 8-32 all thread was proper length. Not to long and not to short.
    The next day we put the body in the milling machine sideways and machined the flats on the post.
    EF9D170E-6E45-4D6D-85B3-6D134D19573A.jpeg 6452E7EE-1068-413F-A638-CDEC0066E797.jpeg AACB7CFD-7135-447E-831C-12796A875A86.jpeg
    After that I went to hobby shop and got a 2.5mm drill (this is the size of the float rod)
    And we laid out the spot and carefully by hand drilled through the existing hole to the new hole with drill bit in dremil tool.
    EFF0684F-432E-4BF6-9271-E98C0EBDEF36.jpeg E696C0F8-3354-4AF5-8642-2B6F97C36C83.jpeg
    There ya go. Fixed.
    Hope this helps others.
    Any questions just ask happy to share.
  2. Tim morris
    Tim morris Active Member Premium Member
    Hopatcong NJ 07843
  3. Tim morris
    Hopatcong NJ 07843
    Congratulations great work and teamwork nice fix
  4. Polock
    nice work
  5. Timbox
    Timbox Well-Known Member
    Really nice fix and great tools to do the job...
  6. Christopher McTavish
  7. SR500ED
    SR500ED Member
    Smithville Ontario Canada
    Don't you just love machine tools!
    However, with a hacksaw and file you can accomplish the same thing.
    Christopher McTavish likes this.
  8. Polock
    true but sometimes a little machine helps
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Might not be a little machine, could be a giant hand!
