Air box size for 82 xj650 seca
Discussion in 'XJ Technical Chat' started by Taylo105, Jun 6, 2016.
  1. Taylo105
    Taylo105 Active Member
    San Diego CA
    so after looking through the Haynes shop manual, I'm led to believe that the xj650 shares the same airbox as the 750 from 1980-1983. Just wanted to see if anyone has any thoughts or experience that contradict this.
    I ask because I just picked up a xj650 seca with cheap eBay pods instead of the stock airbox. After having some issues with idling I'm thinking it might be best to switch it back to the stock system. I just wanted to make sure I don't buy the wrong one -___- haha.
  2. k-moe
    The Seca 650 airbox is not exactly the same as the XJ750 air box, but it is the same as every other XJ650 airbox (Maxim, all years).
  3. Taylo105
    San Diego CA
    Sweet. Thanks for the quick response!!
    I'm looking forward to getting the pods off the bike!
  4. Jetfixer
    Amen !!! The stock airbox is the way to go. Face it the engineers that designed it knew what they were doing , CV carbs do not like large volumes of air. It is much easier to "tune" and jets are easier to figure out , better all around performance.
  5. k-moe
    It's not the volume; it's the velocity.
  6. Jetfixer
    +1 agree
  7. Andyhw
    Andyhw New Member
    Shropshire
    Could they be interchanged though? Is the sizing different? Or is it shape / mounting points that are different?
  8. XJ550H
    do you need a 650 air box? I have an extra one, sell it cheap to you.
    oh I see you are in the UK shipping would be very costly.
  9. k-moe
    Shape, mounting size, and (to some degree) volume are all different.
  10. Andyhw
    Andyhw New Member
    Shropshire
    That is a kind offer thank you. However as you say I believe postage would be prohibitively expensive.
    What is interesting,I have found an xj750E airbox for sale in Japan and it looks identical to the xj750 seca airbox's I have seen.
    As far as I can tell, the xj750E electronics is the only difference between the A and E.
  11. XJ550H
    I am thinking the differances on air boxes is sometimes just the way side covers mount and fancy trim.
