Possible bent cam? Ways to check?
Discussion in 'Hangout Lounge' started by smeagol21b, May 5, 2018.
  1. TheCrazyGnat
    Central PA
    Ok, thanks! I'm definitely not trying to argue, but I didn't understand and my default position is that I'm being a dummy.
  2. hogfiddles
    I can't agree with that........if that were the case then it would go slack like that for all 8 of the valves. The lifter follows the cam lobe.....there is a ramp up and a ramp down. The valves don't snap shut. They slide open and slide shut.
  3. Polock
    i'm glad somebody pays attention. next time you have a cam chain off try it. i found it by spinning the cam to get the sprocket bolts lined-up.
    anytime a valve is closing, it's pushing the cam, most of the time the lifters don't touch the cam. so if a lifter pushes on the top close part of the cam, it has enough leverage to push the cam until another lobe goes through it's clearance and touches.
    so how's that work with four valves...? i don't know but it does, mine did.
    we have to agree it's not jumping a tooth and it's not the sprocket bolts hitting
  4. smeagol21b
    smeagol21b Active Member
    hanover,pa
  5. k-moe
    What's that thing that's rubbing on the top of the crankshaft when the crank is being turned?
    It kind of looks like a guide of some sort, but there is no guide in that position.
    smeagol21b likes this.
  6. smeagol21b
    hanover,pa
    Wow I never noticed that before! I was so focused on the cog teeth and the chain! But I'm sure that's the one guide that has recently been removed/ replaced I'll try to find a pic
  7. smeagol21b
    hanover,pa
    This should be what you were seeing
  8. hogfiddles
    I don't like how the chain is so much to one side.
    Also, what quality chain did you buy, and where did you get it
  9. hogfiddles
    Almost looks like there are two of the same guides...
    Also, is it possible that part of a lower guide has broken off!?! I can't see well enough
    Or was one installed wrong?
    k-moe and smeagol21b like this.
  10. smeagol21b
    hanover,pa
    That's a question better suited for @TheCrazyGnat as he has the guides at his house.
  11. smeagol21b
    hanover,pa
  12. smeagol21b
    hanover,pa
    The guide on the left is the same as the left, I ordered replacements, the one on the right is what was on and bent
  13. XJ550H
  14. smeagol21b
    hanover,pa
  15. XJ550H
    mine does I hook it to my laptop
  16. smeagol21b
    hanover,pa
    I use mine on my phone, i just get frozen images if I get anything at all
  17. k-moe
    The lower part of the front guide seats in the case below and in-front-of the chain. Same for the rear guide. Neither guide should ever touch the crankshaft, and both guide the outside of the chain to prevent it from hitting the cases and cam-chain well. The only guide that runs inside of the chain is the top guide.
    In the video it looks like the guide is resting on the crank, and sitting on the inside run of the chain. That would cause the chain to bind, and then release.
    https://www.yamahapartsnation.com/oemparts/a/yam/500421c6f8700209bc7873b8/camshaft-chain
    smeagol21b and hogfiddles like this.
  18. hogfiddles
    Saw those advertised in the " you just GOTTA have this" stuff on facebook... those kind of ads all say "look at me -- don't waste your money here" to me
  19. smeagol21b
    hanover,pa
    Huh?
  20. hogfiddles
    I see crap like that on Facebook ads all the time. It's all junk
  21. smeagol21b
    hanover,pa
    For my chain? I found that after over an hour of trying to find an aftermarket chain that was over priced....
  22. TheCrazyGnat
    Central PA
    The guides that were in there were the correct guides. The front guide that was all buffered up had to have been installed wrong, or it was severely mangled before installation and they thought it was good enough. I haven't been able to get the rear guide out yet, it is in there pretty good. I can tell it is the correct style (it has that second curved metal piece).
    It wasn't on the inside of the chain, the guide was located in its slot in the head.
  23. hogfiddles
    No!.....the 5mm camera that doesn't work
  24. XJ550H
    I think he is talking about the 6$ bore scope
  25. smeagol21b
    hanover,pa
    Oh! Bahaha forgot we even talked about that! Yeah I forget what mine cost but worked for like a week and died lol
  26. k-moe
    1. The rear guide is held in by a special bolt. It's just below the cam chain tensoner. There is a locknut below it. Removal is easy. Installation requires a simple procedure where you tighten the bolt until it lightly touches the tensioner, and then hold the bolt in place with the locknut.
    2. Then what is that in the video that's rubbing on the crankshaft? Nothing should be in that position.
  27. smeagol21b
    hanover,pa
    Good question...... We will have to look into that further
  28. smeagol21b
    hanover,pa
    Where can I find an engine diagram?
  29. XJ550H
  30. smeagol21b
    hanover,pa
    I can't figure out what that piece is...
  31. XJ550H
    those are the parts to install chain guide the long bolt holds rear guide in place
  32. Polock
    i think if you get guides and a tensioner in it your problem might go away by itself
  33. smeagol21b
    hanover,pa
    I mean the piece in the video that's rubbing on the gear.....I can't figure out what it is
  34. TheCrazyGnat
    Central PA
    I'm sorry, I watched the video three times and I can't seem to see what everyone else is. I see the chain starting to go slack and sort of folding in on itself... Are you seeing something to the side?
  35. smeagol21b
    hanover,pa
    Watch the top of the screen as the teeth come up, I'll send you a screenshot to show you where to look, took me a few times to spot it too
  36. TheCrazyGnat
    Central PA
    Ok, I think I see it. What it looks like to me is that only the top part of the front cam chain was located correctly and was just resting on the cam chain. So when the chain was getting a little slack, the guide was pushing the chain towards the crank. I imagine that is how the guide got so messed up.
  37. smeagol21b
    hanover,pa
    After watching again at 2:10-2:20 on the video you can see it's the chain, the guide was probably bent when the chain snapped in 2016 and the shop left it like that
  38. chacal
    Facepalm.............
  39. smeagol21b
    hanover,pa
    Wouldn't surprise me one bit... Who knows what else is messed up
  40. smeagol21b
    hanover,pa
    Well.... @crazygnat and I have identified the problem....not 1, not 2, but 3 THREE bent valves!!!!!! AcordAcco to the shop there was only one bent valve and they fixed it.....if I put on here how I actually feel about this I'd probably get banned from this site! I've got three valves ordered on next day delivery in hopes that they arrive in time so I can get them lapped and back to crazygnat to get them installed so I can make it to the carb clinic!
    hogfiddles, k-moe and TheCrazyGnat like this.
  41. hogfiddles
    Is this where I say "I told ya so"? Lol
  42. smeagol21b
    hanover,pa
    I think you already did once today but if you must! I just hope we can get everything done in time! If it starts looking like my bike won't be done in time we might have to switch thing up crazygnat's wife's bike so I can ride that! Lmao! Hard to say at this point...
  43. hogfiddles
    Do whatcha need to do--:)
  44. smeagol21b
    hanover,pa
    What can I use to remove heavy carbon build up when carb/ brake cleaner ain't working?
  45. XJ550H
    soak with atf/acetone mix
  46. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    BG products makes an air intake cleaner that works extremely well at removing carbon deposits. Have it at my shop. Only issue is it has to come from a distributor or shop that carries their products. Food for thought, was the first thing that came to my mind. I'm sure there's other products that are cheaper and more readily available
  47. Polock
    i had the heads off a 289 once and scrubbed the chambers with dish soap and water rinsed and covered then with a wet rag, next morning the carbon came out with a garden hose.
    that being said, if you take that carbon out you will lower the compression ratio
  48. k-moe
    And follow up with a medium stiffness brass wire brush.
  49. smeagol21b
    hanover,pa
    I really don't know anything about compression so would that be a good this to lower it or bad?
  50. smeagol21b
    hanover,pa
    I was using a "heavy duty" grill cleaner but notice it said don't use on aluminum so I rinsed it quick, but it did seem to be working! Lol
