Misc. 82 XJ650 Maxim parts.
Discussion in 'For Sale, Trade/Swap, Wanted' started by Gbambeck1, Nov 27, 2007.
  1. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    I have some extra stuff I don't need laying around the house here, just make an offer if your interested!
    Forks with triple trees- probably a good idea to replace the seals.
    Two stators- tested good per Rickomatic's instructions
    I set of gauges- I have to test these. the houseing is in great shape, face is faded a bit.
    Rear wheel with the drive assembly- Turn well no wierd noises that I can hear.
    Pair of mirrors- Believe they are stock, good glass may want to repaint but not in bad shape at all.
    Pod filters and the Crankcase filer?- clean and ready to go.
    Spare Starter motor- Could be cleaned up but otherwise working.
    There's more that I cannot remember I'll update it tonight when I get home!
    Update:
    Also I have
    Stock shocks I think they are 12 inchers (adjustable)
    A set of used coils- not sure if they are good or not (does anyone know how to test these?
    Stock rear brake lever- good shape, good replacement has a little scrape on the bottom but I dont think you would see it if it was on the bike, could always use a grinder to clean it up.
    IC Ignitor- Type TID14-02\ 4H7-10 (Stock Hitachi)
    Oil pan with sensor- needs to be cleaned but looks straight otherwise.
    Rear Brake assembly with new shoes- If someone wanted to polish it or paint it for a custom job or looks good as is.
    Pictures can be taken if you would like just say the word!
  2. schmidtap
    schmidtap Member
    Ft Stewart, GA
    Re: Misc. 82 XJ parts.
    What ya want for just the forks, don't need the tree.
    just looking at the guages, what types and how much
  3. Pacocase
    Pacocase Member
    MD
    If Schmidt doesn't take the gauges, I'd be interested. My speedo housing got bent last summer in a fall.
  4. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    schmidtap and Pacocase you have pm's....
  5. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
  6. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    Bump. Everything is still here... All you have to do is make an offer!
  7. Stormin
    Stormin Member
    Poughkeepsie, NY
    What would you like for Rear Brake assembly with new shoes-?
    And for the Shocks
    Thanks,
    Norm
  8. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    Pm'd.
  9. MiCarl
    Stock handle bars?
  10. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    I dont have any bars... I can probably get you some though, there is a salvage shop near me that sells bars for like 10 bucks they have boxes and boxes I'll see if they ship and get you in contact with them if you would like?
  11. jmk222
    jmk222 New Member
    do you still have the ignitor box?
  12. kgriffin
    kgriffin New Member
    Vermont
    I am in desperate need of your ic ignitor, if you still have it let me know. I WILL BUY IT!
