Let's talk carb cleaning
Discussion in 'XJ Technical Chat' started by Tim morris, Jul 30, 2018.
  1. Tim morris
    Tim morris Active Member
    Hopatcong NJ 07843
    Okay I've gotten a lot of response in different opinions just from over the phone I figured I'd throw this out there as you well know our carburetors are precious and we all want the best results possible I've used carb cleaner in a can I've used spray carb cleaner I've soaked Harley carburetors in gallons of carb cleaner with good success but Here Comes technology and these new Sonic cleaners that heat and they are being praised by many I have a good friend that just spent $1, 000 on one the best one I can't replace my carbs and we've tried and we've seen different results on junk carburetors with different chemicals has anybody use them and if so what fluid do you prefer some say lemon juice some say Royal Purple cleaner other say glycol now keep in mind I know this machine will dissolve anything in it especially aluminum over. Of time so we're only talking a short moment of time that they will be in solution I'm just hesitant until I hear more about it so anybody have any input would be great to hear from you
  2. Polock
    i ran a few bodies through a harbor freight cheapo and rinsed them off with a garden hose, when they dried they were getting that white aluminum corrosion all over them. had to dip them in kerosine. i think brake cleaner, air , a stiff artist paint brush and a few q-tips is sufficient
    Tim morris likes this.
  3. hogfiddles
    I have personally done the 'put the foil in the ultra-sonic cleaner and what the holes develop before your eyes' thing. I'm not about to put an aluminum carb body in my ultrasonic cleaner.......
    SpearChucker and Tim morris like this.
  4. Tim morris
    Hopatcong NJ 07843
    Yes I remember you saying that but has anyone tryed anything else for the solution or base in the cleaner on anything else like disposable parts or other kinds of parts I'm very interested in hearing about everybody's results on all types of stuff and with different stuff I've heard and seen things on YouTube that make glycol look like a very promising solution then I saw one where they used the purple cleaner looks very nice then one where Pine-Sol was used it look nice too but I don't know what really happened as they dried anyway I'm going to experiment with junk parts I'll keep you posted
  5. Jetfixer
    Personally I like Berrymans one gallon carb dip from autozone it contains a small basket to hold parts . Used it on several carbs with good results. Years ago not sure they still make them but denture cleaners used to be a vibrating tray type. I would stay away from pine sol , simple green soak to long and it might etch metal . There are some posts of members having issues with various chemicals .
  6. Tim morris
    Hopatcong NJ 07843
    Yes I've used that also begin information to think advances in technology are not so good sometimes lol
  7. Tim morris
    Hopatcong NJ 07843
    What solution did you use???
  8. XJ550H
    use distilled water.
    when I made contact lenses we would use ultra sonic cleaners and kerosene to clean the lenses.
    you could try kerosene but do it outside or with proper ventelation
    most of the cleaners that come with the ultra sonic cleaner are not for aluminim and say so on the package
    use it to clean the jets and brackets
  9. Polock
    ? hard to tell, whatever was closest. maybe dish soap, maybe car wash soap. i've probably had everything in it that won't burn, including beer :)
    can't say one worked any better than the other. the temperature seems to make the biggest difference, hotter is better. now this is in a harbor freight cheapo, a real machine might be different.
    50/50 antifreeze overnight in a slow cooker frees up old r/c engines but that's dried up castor oil
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Your kitchen must smell weird.
  11. kerriskandiesinc
    NY
    I've successfully.....in the distant past used pure leaded 5 star,( hi octane) not sure what todays ethanol blends would achieve, but that still took a couple of gallons, time and a stiff toothbrush.......plus I couldn't smell anything for a week afterwards.....
  12. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    ...or a great smelling garage. I love the smell of (cooking) Glycol in the morning!
    MattiThundrrr and Tim morris like this.
  13. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I've heard of using jewelry cleaning solution in ultra sonic cleaners. Never done myself but it's been claimed to work well without harming anything.
  14. Tim morris
    Hopatcong NJ 07843
    Lol
  15. Tim morris
    Hopatcong NJ 07843
    Lmao
  16. SQLGuy
    SQLGuy Well-Known Member
    I used the Berryman's bucket cleaner in an older Harbor Freight ultrasonic for the Mikunis off my '89 Virago. I seem to recall a lot of rinsing needed afterwards, but the carbs have been good since the cleaning and overhaul.
