1985 XJ750XN won’t start
Discussion in 'XJ Technical Chat' started by regor52, Aug 4, 2018.
  1. regor52
    regor52 New Member
    Dieppe NB Canada
    XJ750XN won’t start. Just hear clicking in unit behind battery. Any help would be appreciated
    Roger
  2. regor52
    regor52 New Member
    Dieppe NB Canada
    Roger
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Have you tried to jump it? If not, use a car battery (car not runnung). Sounds like a weak battery or loose battery cable.
  4. kerriskandiesinc
    NY
    Starter solenoid also, its right next to the battery......Big round thing
  5. hogfiddles
    Battery is flat
  6. regor52
    regor52 New Member
    Dieppe NB Canada
    Recharged battery. Still get clicking sound from solenoid. Looks like it could be the starter. No reading on the volt meter. Getting it checked out on Monday.
    Thanks for your help guys appreciate it
  7. kerriskandiesinc
    NY
    Did you short across the two large solenoid terminals, see if the starter spins???
    rocs82650 and k-moe like this.
  8. tabaka45
    Brunswick, Georgia
    I would at least try to jump it with a car battery.
  9. k-moe
    Do you get one single click when you press the start button, or multiple clicks?
    Multiple clicks is indictive of low voltage, or a faulty solenoid.
    +1. A quick test to do, but it's also reliant on the battery condition being adequate.
  10. XJ550H
    are you testing for voltage at starter post or output side of solinoid?
  11. k-moe
    Also make sure that the meter leads, or the meter itself, isn't the cause for the 0 v reading.
  12. regor52
    regor52 New Member
    Dieppe NB Canada
    Thanks for the info. Found the problem the starter was full of dust and crap and brushes are almost wore out. Waiting for brushes to come in and also had the core shined up just like new.
    Roger
