Middle Gear Drain Plug Poll -- Is it worth it?
Discussion in 'XJ Technical Chat' started by RickCoMatic, Dec 5, 2007.
After reading the various Posts in this forum regarding the difficulry and ramifcations of trying to
  1. Yes. I want to risk it and my exhaust system needs to be removed and these new easy-outs used &
    0 vote(s)
    0.0%
  2. No. Changing the Oil needs to be less complicated. I'm no fool!
    0 vote(s)
    0.0%
  1. RickCoMatic
    Knowing that several Members have snapped-off the Middle Gear Drain Plug and that it is not necessary to drain the oil from that cavity during a routine Oil Change ... as outlined in the Factory (Not Haynes) Manual ... would you risk trying to get the thing out for less than a half-cup of oil in there?
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I’m lucky my chain has no middle gear oil to change. :lol: :lol: :D
  3. MiCarl
    Ordinarily I'd go try and pull my middle gear plug to see who is right. But since it's 20 deg in the barn, and snowing, I think I'll just take Rick's advice.
  4. schmidtap
    schmidtap Member
    Ft Stewart, GA
    I have it easier, as I have a 4-1 exhaust, still easy to break with the age of bolts....... if you do take it out, replace the bolt
  5. sabco62
    sabco62 Member
    Nothing like participating in a poll based on totally unbiased questions. :)
    It's a bit like going to the ballot box in some small south pacific banana republic, totally fair and democratic as long as you vote for the man who organised the last military coup :!:
  6. RickCoMatic
    Hey, Mon ...
    "Chew gunna vode fur me or my brudder?"
    I could have worded it to be so confusing you couldn't figure-out what to pick.
    "In the confusion, I can't remember if I fired five or six times!"
  7. sabco62
    sabco62 Member
    Or..... Do you think you should drain the oil from the middle gear drain plug?
    Yes
    No
    We've just had a general election in OZ maybe I'm a bit jaded with polls, or we may just qualify as a South Pacific Banana Republic!
    "Go ahead.... make my day!"
  8. rhys
    rhys Member
    Columbia, MO
    No. Drain plugs are bolts and do not have oil inside them. The bolts on brake lines, however, are hollow and should be cleaned out with small pipe cleaners and brake cleaner when you take the master cylinder off for its overhaul.
    Oh, you meant "drain the oil from the middle gear SUMP!" Now I get it...
  9. RickCoMatic
    N-ONFLMAO
  10. gitbox
    gitbox Member
    Talk about yer biased survey questions... :D
    I've got some aftermarket 4 into 2 exhaust on my bike so it's real easy to get to but I voted it isn't worth it for that tiny amount of oil. Heck, I'm sure there's at least that much old oil still scattered around inside the engine.
  11. RickCoMatic
    There is more.
    In the recesses between the Valve Buckets.
    I don't see anyone removing the Cam Cover to sop-up the oil in the Camshaft area.
  12. TOMKAT
    TOMKAT New Member
    Texas
    Hay guy lot of good stuff here . My first post.
    just use your head if just changing oil let go.
    if find metal in the oil might thing about draining it to.
