WTB gas tank top 81 xj650 maxim / Breather filter
Discussion in 'For Sale, Trade/Swap, Wanted' started by greengoon, Dec 4, 2007.
  1. greengoon
    greengoon Member
    Chesapeake Virginia USA
    Hello,
    Looking for a gas tank top as well as a "pod like" crankcase breather for my 81 XJ650.
    Anyone???
    Thanks,
    George
  2. Altus
    Altus Active Member
    London, Ontario
    "Gas tank top"? Are you looking for the gas cap?
    And those crankcase breather filters you can get at any auto parts shop (look in their "tuner" section) or any motorcycle shop will likely have them.
  3. greengoon
    greengoon Member
    Yes ( am looking for the "pop up" gas top that is on the XJ650 gas tank.
    Thanks,
    George
  4. greengoon
    greengoon Member
    OK.......
    I found the breather at PEP BOYS.
    I still need a gas tank pop up lid.......
    Anyone???
  5. Altus
    Altus Active Member
    London, Ontario
    I don't know of a "pop up" lid -- our bikes use the standard keyed lock flip-type gas cap -- are you looking for one of the aftermarket ones they use on cruisers that pop-up?
  6. chacal
    Hey Green, I carry new and used complete gas caps (with keys) in-stock for your bike:
    FUEL TANK GAS CAPS:
    Used caps:
    b2) XJ550/650 (except Turbo)/750/1100 Complete Used Gas Cap with good chrome and key; this cap unit also fits many other Yamaha tanks. This cap comes with and uses an "A" style key.
    $ 39.00
    b3) XJ550/650 (except Turbo)/750/1100 Complete Used Gas Cap with good chrome and key; this cap unit also fits many other Yamaha tanks. This cap comes with and uses a "C" style key. NOTE: this lock unit is keyed to both the powerlock unit (g3) and the ignition switch (e2) listed below.
    $ 39.00
    New caps:
    gc2) OEM Fuel Tank Complete Gas Cap Assembly, with lock and 2 keys. Original chrome-plated, flip-open style gas caps. Brand new.
    HCP2904 OEM Complete Gas Cap with lock and a pair of keys. Fits all XJ550 models, all XJ650 models (except Turbo), all XJ700 non-California models, all XJ750 models, and XJ1100 models. Includes the HCP170 cap-to-tank sealing gasket.
    $ 54.00
    HCP2905 OEM Complete Gas Cap with lock and a pair of keys. Fits all XJ700 California models (SC/XSC/NC/XNC). Includes the HCP170 cap-to-tank sealing gasket.
    $ 64.00
    HCP2906 OEM Complete Gas Cap with lock and a pair of keys. Fits all XJ650 Turbo and XJ900 models. Black finish as original.
    $ 47.00
    xx6) OEM Fuel Tank Gas Cap SEALING GASKET, large round rubber ring gasket molded onto a stamped metal base, with a cinch spring surrounding it. Fits all the flip-open style gas caps that have a metal body. The black-plastic bodied flip-open caps use a different style sealing ring that is not currently available. Fits all XJ550/650 (except Turbo)/700/750/1100 models. If you smell gas when your cap is closed, or if it leaks gas when full, this sealing gasket probably needs replacing!
    HCP170 OEM gas cap Sealing Ring, each:
    $ 13.00
    c6) Aftermarket Gas Cap-to-Tank Mounting Screw, original fit and function. Original mounting screws were made of a plain alloy steel, and did not use a lock washer; these replacement screws are available in a variety of styles. Fits all XJ550/650 (except Turbo models)/750/1100 models.
    HCP910 aftermarket gas tank fuel cap Mounting Screw, zinc-plated alloy steel with correct pan head size and using a phillips drive slot.
    $ 1.00
    HCP2748 aftermarket gas tank fuel cap Mounting Screw, 18-8 stainless steel with correct pan head size and using a phillips drive slot.
    $ 2.50
    HCP2749 aftermarket gas tank fuel cap Mounting Screw, 18-8 stainless steel with a black-oxide coating, featuring the correct pan head size and using a phillips drive slot.
    $ 1.50
    HCP2750 aftermarket gas tank fuel cap Mounting Screw, 18-8 stainless steel with correct pan head size and using a phillips drive slot. Has an integral externally-toothed captive "star" (sems) lock washer.
    $ 2.50
    All this and more over at:
    http://www.xjbikes.com/Forums/viewtopic ... t=135.html
  7. greengoon
    greengoon Member
    My stupidity on the term "pop up" it is indeed a key style tank lid.
    CHACAL..........
    Iwill ne getting with you soon on a replacement top as well as some other parts Thanks for the quick reply!
    Thanks,
    George
