No bolt left untouched (project build)
Discussion in 'XJ Modifications' started by Drake, Sep 19, 2017.
  1. Drake
    Drake Member
    New Zealand
    Engine fitted into frame.. with wheels so I could see the stance the bike was going to give
  2. Drake
    Drake Member
    New Zealand
    Strip the tank and seat back off and start playing with this factory loom!!
    Stock loom vs new components... motogadget
  3. Drake
    Drake Member
    New Zealand
    This is all I kept from the factory loom
  4. Drake
    Drake Member
    New Zealand
    Many many hours of wiring !
    this M unit is one seriously impressive bit of kit!
  5. Drake
    Drake Member
    New Zealand
    Old cockpit set up vs new
    Hiding the wiring inside the bars was by far the hardest part of it all..
  6. Drake
    Drake Member
    New Zealand
    Old headers and 2-1 collectors wore rusted out and pretty much rubbish so made some new ones ... shorter.much shorter..
    Franz likes this.
  7. sybe
    sybe Active Member
    NYC - Brooklyn
    Nice build its all clean. Love the handle bars controls. Are you mounting the choke at the handle bars or a short lever pull onto the frame and or motor?
    The clear tube master cylinder is cool i looked at isr radial mc's that are built for that setup. The major complaint is the brake fluid gets dirty faster as there is less to mix as a tanked mc. Still like it and want to do it.
    Drake likes this.
  8. Drake
    Drake Member
    New Zealand
    Hey mate
    Nope I just manually left the choke tab where the cable would normally mounts
    Only needs 10secs worth of choke anyway so it’s easy at the mo
    Yes I got the tube from ISR.
    I plan on upgrading the whole front end at some point anyway.
    Forks and brakes are horrible even after a rebuild.
  9. sybe
    sybe Active Member
    NYC - Brooklyn
    I hear you on the front end. My master cylinder has too much tension and the air requirement for the xj650 forks drive me nuts. looking to replace it with a more modern system. Just cant justify the cost for the r6 fork upgrade. Also i dont want to do clip on handle bars.
    Did you do the nissin mc mod with the isr tube or full isr radial mc?
  10. Drake
    Drake Member
    New Zealand
    I hear you on that one!
    Price for a modern front end is very expensive.in my country it’s a bit outrageous.. but will keep searching.
    I also don’t want clip ons
    It is a early Yamaha R6/R1. MS
    I also brought the calipers to but my model of work has that odd mounting set up so I can’t really make a adaptor for the calipers unless I make new and weld new lugs
